Wheel spacers(front)
my escos as 18"rondells on it and there are spacers on the front about 5/6mm. does anyone else have spacers on with their rondells? it just has standard brakes on with bilstein suspension. was maybe thinking they were put on to clear the bilsteins.
Originally Posted by Paul Ripley
bilstein suspension as in coilovers?
they are not coil overs. just normal springs and shocks.
Yeah prob was to clear the shock then do you know yours wheels ET offset?
Rondells are all ET18
Sometimes when running a 235 tyre they can catch on the front suspension, but most people run 225 tyres. Cant understand why you'd have 6mm spacers?? That would be ET12!!!
Try them without, you should have any problems
I am running 225 and use to have 5 mm spacers with KONI's I had to flatten the spring cup with a club hammer to make the tyres clear.... I since taken the spacers off and its been fine.
going coilovers very soon, so thinking off running 235's
yeh later type cups were design with more of an angle to solve this problem. so if your suspesion is rather new, then id imaging yours are fine.
Take the wheels off and the spacers, put them back and if your can fit the thickness of your finger between the back of the tyre and the cup, you will be fine...
i am glad this one has come up, i run toyo proxy r888 235 40 17 on raceline wheels and the tyre rubs on the front spring cup at speed (120mph + ) dont want to go coilovers as its a road car. its got koni front legs but have been on there for 5 yrs + , are you saying if i just get new legs it will sort it ????
cheers for any help......
you will need a club hammer mate and plenty of strenght, it took me and me mate to make the cups to the specified clearence...
but if your prepared to take the legs off, then you could get them modified so the tyre side of the cup is flat insted of round...
just out of interest why are most of ya taking off the spacers ???
i understand the ET numbering offsets, is that the only reason ???
like i say only out of interest
Caraholic
cheers , i will take them off to be repainted anyway, may have them cut/ welded up and repowder coated, will post pics when done if anyone is interested ??????
09-10-2015 07:38 PM
borboyous
22-08-2015 11:17 AM
