1.8tdci Leak Off Test
Old Jun 17, 2022 | 08:05 PM
JackW's Avatar
JackW
Default 1.8tdci Leak Off Test
Hi guys,
Having a pain trying to figure out what's up with my 55 plate focus 1.8tdci, wont get into it unless i have too.
But basically does anybody no the tolerances for how much the injectors should leak off ? And if so how did you test it (example; idle 30sec, 3k rpm 30sec e.c.t e.c.t)
Hoping that once I change my injectors and test them should shed some light on this problem ive had for 6+ months now
Thanks everyone👍
Old Jun 18, 2022 | 07:18 PM
GVK.'s Avatar
GVK.
Whats your issue first of all, and fault codes if available?
https://www.fordwiki.co.uk/index.php..._Leak-Off_Test
When we used to be changing tdci injectors for warranty on Mondeo/Transit/Focus, we just tested them at idle , 1 min, 4 min and 8 min.
But tbh , a bad injector will fill the small bottles Fords supplied in 1 min if it was a particularly bad one. I cant remember the tolerances now its 15 yrs ago lol, we just used to tell them over the phone our results and they would either advise a new injector or not - which was a pain if you knew in your own mind the thing was knackered or not. - some info on this thread , https://passionford.com/forum/ford-m...test-help.html
https://passionford.com/forum/ford-m...-please-2.html
Old Jun 21, 2022 | 04:21 PM
JackW's Avatar
JackW
Hi mate ,
Only fault shown was p0190
When running it will run and idle perfect (apart from limp mode that's permanently on) and will start up again no problem , but now it won't start atall (after a few months of difficult starts e.c.t tapping throttle)
So looked into it , ended up changing FPS and checking whole loom back to ecu for faults , nothing. No relay or fuse problems.
So next port of call is to change the injectors as apparently excessive leak off can play with the readings an if ecu picks up on it it will disable fuel pump to start? Not sure if true but only thing I can find
Plus because if pump was knackered it wudnt run right when started would it ? Any advise is appreciated
Thankyou👍
Old Jun 21, 2022 | 07:03 PM
GVK.'s Avatar
GVK.
Yes, If there is excess leak off then the ECU will shut down, the P0190 in your case is more of a fuel pressure problem. Could be pump but really you need diagnostic tool that show fuel pressure. For the car to start you need at least 250 bar, to test the pump you need to disconnect the injectors and the fuel pump wiring (inlet metering valve) then crank with the diagnostic tool showing fuel pressure , the delphi pumps should reach 1600 bar with good pump, filter, and injectors.
What I uaed to do was check the leak off when doing the fuel pressure test at the same time, if there was any fuel in the tubes on cranking , bingo theres your injector fault.
I know it sounds basic but whens the last time you had a fuel filter?
fordsportjay
Sep 24, 2011 11:03 PM
twoblacklines
Jul 20, 2010 12:50 PM
Oranoco
20
Sep 11, 2008 07:47 AM
Garage19
Concours d'élégance.
Jun 11, 2008 08:16 PM
icelollies
44
Apr 6, 2006 05:23 PM
