16v head to 8v block
Old Nov 24, 2021 | 06:08 PM
Rirsa's Avatar
Rirsa
Default 16v head to 8v block
Has anyone ever put a 2.3 L 16v head to a 8v block. I was thinking about putting a 16 v on my sierra engine because the 2.3 block is probably cracked and it mixes oil and coolant i have changed the head gasket and the head and block have been machined flat. So that shoumdent be the problem.
Old Nov 24, 2021 | 06:17 PM
Mark V8's Avatar
Mark V8
2.3 head has larger combustion chambers to match the bigger bore of the 2.3 engine.
You would need a 2 litre 16v head
Old Nov 24, 2021 | 06:38 PM
Rirsa's Avatar
Rirsa
So if i get a 2L 16v head so it just bolts up do i need to make any changes to the timing side i dont worry about the electrics because its getting a standalone ecu, ITB:s and headers
Old Nov 25, 2021 | 09:41 PM
dojj's Avatar
dojj
Resident Wrestling Legend
assuming you are talking about the I4 engine you can certainly bolt the 2.3 16v head to the 2.0 8v bottom end and everything will line up and work
however the compression ratio is up to around 11.8:1 so you'd either need to fit a thicker head gasket or remove some material from the chamber
you'll also need to do some ecu stuff
and fit the coil packs
but once it's done you'll get v6 power and torque levels for 4 cylinder fuel economy
Old Nov 26, 2021 | 02:19 AM
christos's Avatar
christos
10 Year Member
Amazing. I didn't know that the 2.3 16v cylinder head is straight bolt on the bottom of the dohc 2.0 8v
Old Nov 26, 2021 | 06:02 AM
Caddyshack's Avatar
Caddyshack
yes it will bolt up but won’t work as the combustion chambers won’t match. (Based on what is in the answers to this thread)
Old Nov 26, 2021 | 06:28 PM
Mark V8's Avatar
Mark V8
2.3 head lowers compression on a 2 litre and overhangs the bores.
I'm sure someone has done the 16v head swap on this Facebook page
https://www.facebook.com/groups/217128698464709
Old Nov 29, 2021 | 06:45 PM
Rirsa's Avatar
Rirsa
Yes talking about that engine. is the 2.3 head different to the the 2.0 16v head if so by how much? I am also debating on do i need to change pistons because of the compression or can i just take some material out of the stock pistons.
Old Nov 30, 2021 | 01:28 AM
dojj's Avatar
dojj
my mate did it about 15 or so years ago and removed stuff from the heads as much as he dared
i think i've still got the gasket kit from when i sold him the engine lol
he was running on after market management though and while everything worked i think it was a case of him having other plans and he retired it after a few years
efiturbocab
Feb 19, 2010 09:29 PM
Chip
Apr 19, 2007 06:22 PM
Tank Mike
Mar 25, 2007 09:37 PM
abdr500
Sep 10, 2006 10:48 AM
makaveli662
Nov 23, 2003 04:07 PM
