Focus ST225
Old Apr 23, 2021 | 03:15 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Default Focus ST225
Well it was 3 years ago that I sold my Focus ST170, and although I still have my Carina E project car, I've decided to add an ST225 to my collection lol.
It's the first turbo car I've owned in over 20 years, the last being a RWD Sapphire. I'll hopefully post up some videos and photos of the Focus and the work being done to it. Thanks for stopping by.
Old Apr 23, 2021 | 04:25 PM
smiley's Avatar
smiley
Cool mate got an 09 st3 just after christmas been garaged while I get my bits together got cooler so far going full rs rep sprayed Mercedes piano black 340 bhp to start 😂😂
Old Apr 25, 2021 | 09:47 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
That sounds awesome, I'm looking to sort the suspension, exhaust, intake, etc, and hoping for a safe 300bhp, a little bit of interior removal, i.e. rear seats etc, some chassis braces, and bigger brakes, that should see me happy
Old Apr 26, 2021 | 05:37 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Here's a quick video of me talking through some of the things on my new car.
Old Apr 27, 2021 | 08:23 AM
Nice car Paul. Looking forward to the updates.
Old Apr 30, 2021 | 07:45 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Thanks Glen, the Toyota has sold, so I'm 100% committed to this project
First off I'm fixing all the faults, then I will start to play.
Old Apr 30, 2021 | 06:15 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
They are good cars. Shit on fuel lol but I do like mine. Just had to fit a new maf sensor on mine also send the dash off to be re soldered. Panther black is definitely one of the best colours along with sea grey
Old May 3, 2021 | 05:15 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
That's the best colour lol.
Old May 3, 2021 | 05:16 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
I've started to clean mine, whilst I start a shopping list for parts lol.
Old May 7, 2021 | 07:47 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Does anyone know of a good step by step guide to engine tuning the ST225, i.e. parts and order of install. I've a couple of grand I want to put into the car, and I'm not sure on places to buy, and what to buy, thanks.
Old May 10, 2021 | 02:59 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
I spent 10 mins cleaning the plastic in the engine bay
Old May 14, 2021 | 09:30 PM
nathansRS's Avatar
nathansRS
c++
Nice!
Got mine a few years back on a whim and just can't stop driving it.
A bit disappointed with standard power, but they have so much more to give, it's crazy not to tap in.
Here's what I did if it helps, as I started stage 3 and ended up stage 4.
BTW I will be letting all my stage 3 bits go soon and as I have been looked after by a few guys on here, if you want them I would let you have the whole lot for *400!
Anyway, here's what I did:
First I tried stage 3 - *these are my stage 3 parts:
Collins CP340 software and USB and OBD cable including diagnostics - used once!
New Bosch Focus MK2 RS injectors - used for 150 miles! - still boxed with caps either end lol
Pro-Alloy intercooler - fits standard st225 piping - excellent quality intercooler
Mongoose 3" sport cat and large downpipe - the car already had 3" non res turbo back.
Focus MK2 RS plugs
This was really good - if you look at the dyno curve on Collins' site you can see how the power is held at the top end.I used the MSD340 actuator
But I had tasted the rush of crazy torque, so...
My stage 4 spec now:
Focus MK2 RS oil cooler
Focus MK2 RS clutch
Focus MK2 RS radiator
Heavy duty actuator
Forge recirc
KRS turbos k06 hybrid turbo & stainless braided oil feed
Airtec stage 4 intercooler with large boost pipes
Wayside stage 4 mapping
340 LPH fuel pump
Bosch 550 injectors
CAIS
block mod
Ali crank pulley
Airtec 3.5" downpipe
The brakes aren't bad - I have just added yellowstuff pads and slotted discs which made a big difference.
It is now just as I wanted it and it is so comfortable you can just cruise around listening to the burble or getting 40mpg on the motorway and it will pick up really fast in 6th even at 2700 - and it has been really reliable too.
One other bit of advice if you have't done it is to use epoxy to glue the bonnet lock in the contracted position, they never fail once you have done that.
I also did the block mod on mine and while you are there it is good on these to ensure the timing is properly aligned with the tool in the cam end - leave the sprockets free wheeling and line them up to the top of the timing cover while the other end is locked by the cam tool before tightening.
I did the clutch on my drive and bought the RS LUK clutch and CSC kit for about 180 (the st flywheel was in good condition) so the car is not expensive to mod, especially if you don't mind doing a bit yourself. It's well designed and good to work on.
A lot of the time it is easier to get parts from Volvo - for example the rod cap bolts were stupid expensive from Ford, but really cheap direct from Volvo.
Have fun!
Old May 15, 2021 | 12:48 AM
ajamesc's Avatar
ajamesc
what’s this about? I’ve seen a few with the bonnets gone up on Facebook. What do you bond?
Old May 15, 2021 | 07:53 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Nice!
Have fun!
Cheers Nathan, a lot of good advice, I've already replaced my bonnet lock system, as it broke the 3rd time I opened it lol.
Old May 16, 2021 | 11:35 AM
nathansRS's Avatar
nathansRS
c++
At the slam panel end of the cable there is a flawed security design where the lock mechanism on the slam panel and the cable from the front grille are connected by a small plastic cross piece. if pulled too far apart the cross piece can dislodge. There is a company doing an extended cross piece which is supposed to take up the slack but then all the pressure is on this tiny piece which also does not have the end hooks like the ford one.
If you just undo the lock from the slam panel you will see the plastic part that moves up and down. If you fix it in the contracted position it can't move and the plastic piece has to transmit for a shorter duration and can't dislocate.
Old May 18, 2021 | 04:21 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Well having bought a replacement, mine broke just before fitting it lol.
Old May 20, 2021 | 07:32 AM
nathansRS's Avatar
nathansRS
c++
Unhappy
https://youtu.be/QyOE2CWopB4
Nice vid, I like your style of explaining things.
Shame, as you could have fixed that without a new one if I had posted sooner .
There are 2 types of failures -
the cross connector becomes slightly dislodged (can be forced back in with screwdriver) and where the cross connector has moved completely and has no connection, or has broken, in which case you need to break off the moving part and can't reuse it.
In your case the 'lateral movement' you refer to is not wear, they are like that new.
it is an awkward attaempt at a security device . In your case if you had time to use an expoxy to bond in the contracted position (removing the movement and slack) it would have been ok.
Still easy to say that after right!
Good vid, keep them coming and good luck
Old May 24, 2021 | 04:03 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Thanks Nathan, I appreciate the tips
In the future I may look to removing it altogether and having bonnet latches ?
Here's a new video of me removing the awful mud flaps lol.
Old Jun 2, 2021 | 08:16 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
I'm still busy working away at the little faults on this car. Here's a video where I sort out the dash display problem.
Old Jun 7, 2021 | 05:32 AM
rayben's Avatar
rayben
https://youtu.be/pTHEFeYbvBs
Nice. It looks a lot better without the mud flaps.
Old Jun 7, 2021 | 07:08 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Thanks, and I so agree
Old Jun 7, 2021 | 07:09 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
It's Monday night, so here's another video.
Old Jun 14, 2021 | 04:50 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
I'm still busy working away on my Focus
Old Jun 15, 2021 | 01:03 PM
How come you have sold the Toyota??
Old Jun 21, 2021 | 04:46 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
I got tired of not being able to get the parts I needed, plus I've got to have a fairly major op later this year, so I'll be out of action for a while.
Still doing small jobs to the ST though.
Old Jul 3, 2021 | 09:00 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Well I've been after some Team Dynamics Pro Race wheels pretty much since I bought the ST, but I've not been able to find any. So when I spoke to Demon Tweeks they said these new wheels had been released this week by Team Dynamics, so I ordered a set along with some sticky Advan tyres... It's transformed the car, and saved weight.
New wheels and tyres.
Old Jul 3, 2021 | 09:04 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
A new video is up.
Old Jul 3, 2021 | 04:59 PM
As said on Instagram,looks nice on them wheels.
Old Jul 8, 2021 | 05:55 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Thanks Glenn
Old Jul 8, 2021 | 06:23 PM
ajamesc's Avatar
ajamesc
Looking good the wheels sit well with the car
Old Jul 10, 2021 | 07:47 AM
RichieST's Avatar
RichieST
Here's mine, I've spent a fortune on it since I've had it. Love it to bits. I owned my first one back in 2009 and sold it due to expensive kids, houses etc.
I love this one, probably won't sell it for a long time.
Old Jul 10, 2021 | 08:43 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Thank you for the kind words.
Old Jul 10, 2021 | 08:45 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Originally Posted by RichieST
I owned my first one back in 2009 and sold it due to expensive kids, houses etc. I love this one, probably won't sell it for a long time.
Gotta love the purity of a white car.
Old Jul 10, 2021 | 08:47 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Here's this weeks little video, thanks for the views.
Old Jul 15, 2021 | 05:59 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
I'm still busy working away on my ST as and when I can
The other week I changed the cabin filter.
Old Jul 23, 2021 | 07:37 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
A few weeks ago I fitted some new wheels and tyres, this is the video about it thanks for any views.
Old Jul 30, 2021 | 09:06 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Well a week later and I've fitted some locking wheels NUTS..
Old Aug 6, 2021 | 11:03 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Started to try and sort the bumper out.
Old Aug 12, 2021 | 04:51 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Still working away on my Focus ST I've got some big parts on order
Old Aug 20, 2021 | 10:27 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
I took the ST over to Halfords to have the AirCon checked and re-gased.
