Sierra 2.0- 2.9 v6
Hello!
I need advice with the swap.
s far as I've heard and researched, I need to buy the following things.
engine, engine wiring, scorpio ecu, v6 type9 gearbox and clutch, flywheel and pressure basket.
Do I need anything else?
What do I have to consider? Is everything plug and play? And maybe someone has already survived it and can give advice. All information is useful!
Thanks!
Thanks!
Hello!
Thanks!
Thanks!
And the 2.9 is form ford scorpio
Also make sure you get the starter motor, alternator, power steering pump and cooling hoses. For the gearbox youd better get a MT75, its quite a bit stronger and shifts nicer than a T9.
You do need a prop shaft that goes with a MT75 box. The diff (is that what you mean with rear axle?) does not need to be changed.
Depending on what engine you have now you might also need a different fuel pump. The 2.9 uses an electric fuel pump and a return line, just like the 2.0i dohc engine.
Granada24v
Jul 27, 2015 04:48 PM
darren.cudd
Jan 25, 2005 01:09 PM
