Starting problem on series 1 RST
Old Sep 1, 2019 | 06:13 PM
GrahamLaw's Avatar
GrahamLaw
Default Starting problem on series 1 RST
Hi. Series 1 has developed an intermittent problem with starting. Can hear fuel pump running but when I second turn the key there is nothing. No cranking, silence and very little dip in ignition lights.
Sometimes has overrun when turning off and I can remove key from barrel before engine is off.
Went to show yesterday (very wet) no problems. This morning absolutely nothing.
Dont think it is starter and battery is quite new. Could it be solenoid and if so how do I change it.
Many thanks for any help.
Old Sep 2, 2019 | 09:39 AM
james kiely's Avatar
james kiely
Put it in second gear and rock the car back and forth.then try starting it in case the starter is getting stuck.also check all your connections on the battery and starter.alternatively it could be your ignition switch on it's way out.
Old Sep 2, 2019 | 02:23 PM
davidfox280585's Avatar
davidfox280585
Common for ignition switch failure
1812armed
Mar 9, 2019 02:10 PM
ricky g
Apr 6, 2015 04:37 AM
havv
Jun 11, 2007 07:21 PM
leekellett
Jan 23, 2006 07:08 PM
c5tto
Aug 27, 2005 10:12 AM
