Series 2 starting problem when hot.
Old Apr 5, 2015 | 10:33 AM
ricky g's Avatar
ricky g
Default Series 2 starting problem when hot.
Morning everyone, I recently bought myself a H reg series 2, loving the car so far but I do have a Couple of issues to get sorted, the main problem is when it's up to normal running temperature it refuses to start from turning on the key, it doesn't click, doesn't turn over slowly, just nothing, the lights dim on the dash when you try
To turn it over but it just doesn't turn at all.
I've read a few previous peoples posts who have had the same problem but here's the strange part, if you put a jump pack on the car it fires up straight away with no hesitations. It has a new battery, looks like a new starter motor and the exhaust is heat wrapped. So has anyone had similar problems? Also if you leave the car for a couple of hours it starts up fine. Any help or advice is much appreciated.
Ricky
Old Apr 5, 2015 | 06:30 PM
Fordmad!'s Avatar
Fordmad!
Still sounds like the downpipe is cooking the starter. Try heat wrapping the starter too to see if that helps
Old Apr 6, 2015 | 04:37 AM
bigryrs's Avatar
bigryrs
RSHoleinator
2002 transit connect starter! Fit and forget man!!
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
marky_g
18
Aug 26, 2015 03:42 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
nick8saff
Aug 16, 2015 05:35 PM
