Cooling system question????
Old Apr 30, 2019 | 12:08 PM
Jamie_EscortSport's Avatar
Jamie_EscortSport
Default Cooling system question????
Having just started using the car since rebuilding it over the last 7odd years.
So far only done around 40 miles whilst running the engine in, the car doesn't over heat at all and sits quite comfortably half way.
I have noticed when I turn it off that the hose just before the thermostat is bubbling a fair amount.
The cars has new hoses, new alloy rad, Waterpump and low temp thermostat. Am I missing something?
Having checked all hoses they're all getting hot as you'd expect so I can't see a blockage also pulled the vent pipe of the top of the housing the shift any last remaining air.
Any advice would be good
Old Apr 30, 2019 | 12:26 PM
haz87's Avatar
haz87
Which hose as there are 3 at the themostat?
Regardless, bubbling means air. Is the header tank cap on proper tight? No weeps/leaks anywhere?
Edit: was the system bled properly in the first place?
Old Apr 30, 2019 | 12:31 PM
Jamie_EscortSport
Valid point! The main rad hose to thermostat.
Header tank and cap are both brand new items and tight!
This is my reckoning Brigg an air lock but for some reason (if it is) can't shift it. Was originally run up to temp with cap off and once cooled refitted etc, heaters blowing hot as they should, tried to purge with the top thermostat hose off too
Old Apr 30, 2019 | 12:53 PM
haz87's Avatar
haz87
Does sound like you've covered bases. When you bled it, was the car relatively flat? I have known air to get trapped in the heater matrix when the cars been parked at a funny angle and this can be an arse to push out. Usually not too troublesome on Escorts, but not impossible...
Old Apr 30, 2019 | 12:58 PM
Jamie_EscortSport
Yeaa I thought that too ��
Was sat in the garage flat, I thought to a point they self bled anyways. Will give it a few more miles and see if it changes
Old May 1, 2019 | 09:05 PM
boost monster's Avatar
boost monster
Mine has always done that.
Old May 1, 2019 | 09:19 PM
Jamie_EscortSport
And you've never had a problem with it? Does it build up a lot of pressure in the tank or anything
Old May 6, 2019 | 06:31 PM
boost monster
Never had a problem. It just bubbles away till it cools down.
Old May 6, 2019 | 06:36 PM
Jamie_EscortSport
Seems exactly what mine does too 🤷🏽*♂️ not once overheated or anything
Old Jun 26, 2019 | 08:43 PM
Spicy's Avatar
Spicy
Hello, guys do you know anyone that sells the whole electric beam or can supply me a lot of picture of it and lengths to duplicate it thanks a lot
Old Jun 27, 2019 | 08:10 AM
haz87's Avatar
haz87
What??
Old Jun 27, 2019 | 08:53 AM
Spicy's Avatar
Spicy
the electric beam of the ford escort rs turbo, one of my friend needs it, please
Old Jun 27, 2019 | 10:15 AM
haz87's Avatar
haz87
Given you've spammed half the posts on this forum with the same question, I'm now interested - what on earth is an electric beam?
Old Jun 27, 2019 | 10:39 AM
Spicy's Avatar
Spicy
in french is "faisceau électrique" which is mean all wires and connectors for the entire vehicle
Old Jun 27, 2019 | 12:18 PM
haz87's Avatar
haz87
You're after a "loom" in that case. Either way I'd suggest you start a new post in the Wanted section (need to be a gold member) rather than posting all over technical queries from others
M K
Mar 3, 2014 11:33 AM
Stu_K
Oct 22, 2012 12:57 PM
b_kennedy
Feb 9, 2009 12:17 PM
CosRush
Apr 27, 2006 06:41 AM
Ford Escort RS Cosworth
Dec 11, 2003 08:04 AM
