Pectel Management
Old Jun 17, 2018 | 05:58 PM
Pardeep's Avatar
Pardeep
PF's Guitar God!!!
Default Pectel Management
Evening
Just wanted to know if anyone has setup a pectel T2 on a MK1 Focua RS and how they are finding it? As the car is stripped, thinking the new engine will benefit from an improved management so any wiring can be done now rather than later.
Old Jun 17, 2018 | 06:24 PM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
Hi not run one in a mk1 , but pectel t2 is a good upgrade , fully mappable and has a few features but not overly complexed like the more expensive ecus. Does a good job. Ian used t2 on all his engines that ran big power for reliability and he used Ahmed and Harvey to do the mapping and dyno so you couldn't get any better. I built most of ian pectel t2 looms for many different cars including mk1 focus and I still run t2 on my engine and most probably will carry on as it's a cheap Motorsport proven Ecu.
Let us know if you need a loom lol
Cheers paul
Old Jun 17, 2018 | 07:46 PM
Mark Shead's Avatar
Mark Shead
It’s a very basic Ecu so you may want to look at what you want it to do.
Any good aftermarket Ecu will be a improvement but most of it is down to the mapper. Choose the one you want to use and go with what they say.
Mark
Old Jun 17, 2018 | 07:48 PM
Caddyshack's Avatar
Caddyshack
Seems odd to add an ecu that is older than the car it is going on?
Old Jun 17, 2018 | 09:01 PM
zetaboostboy522bhp
Why ? There's nothing wrong with t2 , and I don't think there is any age difference as ford used it on there promo t230 Ford Focus car . It's cheap and I would rather have that that some old Cossie ecu that's with a pectel board and people are still fitting them to cars now. Unless you want to spend over Ł2000 now your limited unless it omex or megasquirt.
I would swap to t6 but they go for Ł1000/Ł1500 secondhand and new pectel sq6 are more than that just for the ecu alone.
I would like to use life racing but they are expensive so tbh iam not going to gain anything.
Cheers paul
Old Jun 17, 2018 | 09:33 PM
Jay,'s Avatar
Jay,
Sponsor
such a old ecu no back up anymore its very basic id be thinking more modern tbh
Old Jun 17, 2018 | 09:59 PM
Pardeep's Avatar
Pardeep
PF's Guitar God!!!
Cheers paul
I will be so it's good to know you are someone I can contact for the loom.
Mark
The car is to be a "Great" track car but an even "Greater" road car. My other option is to for an EMU ECU master setup BUT I'd need a custom loom to get a digital dash to work.
Old Jun 18, 2018 | 07:19 AM
Mark Shead's Avatar
Mark Shead
you would need a custom loom for both. How you working the idle control with the t2
Mark
Old Jun 18, 2018 | 09:11 AM
Caddyshack's Avatar
Caddyshack
Cheers paul
I had assumed that the poster actually meant an old cossie one but obviously not. I know I would not want megasquirt.
Old Jun 18, 2018 | 11:01 AM
t230's Avatar
t230
T2 for me was a nightmare - my Focus T230 ecu was locked - no support - no one willing to unlock - got rid - had my ford ecu mapped by Sabre - havent looked back
Old Jun 18, 2018 | 11:46 AM
lacey's Avatar
lacey
T2 is good but dated not sure it's even made anymore
I paid Ł500 for a t2 with a proper loom for my pinto turbo
As it will be fine
Had a t6 years ago good Ecu but was always breaking
Life racing f88 entry level is Ł850+vat which is a very capable Ecu
And there is loads more in it to be unlocked if you need it
Old Jun 18, 2018 | 03:18 PM
justin2's Avatar
justin2
I had a Focus T190 years back with an Ian Howell specced engine running a modest 360 bhp (engine specced for 500bhp) that was firstly mapped by Ahmed Bayjoo then mapped by Harvey Gibbs and its a very good ecu for the money in fact it’s better than most others for the same money, but listen to Mark Shead on here use whatever the mapper of your car suggests as he will get the best out of it then for you!
Breda
Oct 31, 2011 06:08 AM
Damo V
May 19, 2006 10:11 PM
DaveEscos
13
Oct 10, 2005 06:50 PM
gavintwopies
May 13, 2005 07:37 PM
Spiky
60
Feb 7, 2005 11:47 AM
