to fit pectel monitor to pectel t6 2000
I have a T6 2000, and I want to connect a pectel monitor like this one:
The monitor has this big plug with 16 pins
My loom does not have this plug. How do I connect the monitor to the loom??
BTTT
try PM'ing Gareth T
he is a helpful chap, and if you look here you will see he is running T6 and pectel monitor....
https://passionford.com/forum/viewto...063&highlight=
try PM'ing Gareth T
got the pm,, i sold my montiro just before i got my t6 so never tried it,, but im sure you can config the coms output for the monitor,, ill have a look alter and see what i can come up with for you guys
i think its as easy as going too your engine software set-up page (press "m" in descpro)
then "miscellaneous" downt he bottom
default communitcation mode,,, set as pectel
i cant remember how the monitor is wired and i cant find my manual for the monitor
can you buzz out what pin them three connections go too,, and i may be able too help you more
JoeyBoyden
18-08-2015 10:52 PM
muz
16-08-2015 12:57 PM
