pectel monitor owners with P8 management..... read on
Old 10-10-2005, 05:06 PM
DaveEscos
DaveEscos's Avatar
Default pectel monitor owners with P8 management..... read on
does the ECU need modding / programming to talk to the monitor?
or should it just be plug and play ?
im getting a no communication to ECU message on the monitor
Old 10-10-2005, 05:10 PM
gus
gus's Avatar
the one i borrowed was plug and play
Old 10-10-2005, 05:14 PM
The DIVA
The DIVA's Avatar
If it`s a genuine Pectel monitor i presume it will need pectel software in the ecu....
Old 10-10-2005, 05:15 PM
Eagle Systems
Eagle Systems's Avatar
the ecu on my escort cossie needed modding as it has P8 managment
Old 10-10-2005, 05:17 PM
jon@work
jon@work's Avatar
My P8 (without Pectel board) needed something "switched on" on the chip whilst being mapped to work my monitor.
Old 10-10-2005, 05:18 PM
gus
gus's Avatar
may be mine had what it needed then
Old 10-10-2005, 05:19 PM
DaveEscos
DaveEscos's Avatar
aah.. this could be my problem. Yes im using P8 aswell
any idea if the switch in the ECU is a 'manual' one or a software one?
Old 10-10-2005, 05:20 PM
Eagle Systems
mine had a pectel board already and needed extra wiring done inside the p8 box to make it work.
dont know what it was as grove did it all (ahmed blowjob)
Old 10-10-2005, 05:23 PM
jon@work
jon@work's Avatar
software switch required, I believe
Old 10-10-2005, 05:25 PM
DaveEscos
DaveEscos's Avatar
cool, ill give ahmed/harvey a call tomorrow
Old 10-10-2005, 06:23 PM
GARETH T
GARETH T's Avatar
i had to pay something like 60 quid to have my data stream turned on when i had a p8! it had a pectel/ahmed board fitted
Old 10-10-2005, 06:26 PM
markk
markk's Avatar
needs an internal board mod as well for p8
Old 10-10-2005, 06:29 PM
DaveEscos
DaveEscos's Avatar
right, with the engine running, if i turn it to datalog, then back.. it reads ok.. but cerain features arent on there.. ie water is 0 , fuel time is ) etc..
looks like i need my ecu sorted then
Old 10-10-2005, 06:50 PM
Billabong
Billabong's Avatar
Ahmed/Harvey supplied chips usually have datastream switched on (software) but as Markk points out, the P8 ECU board will need a slight 'hardware' mod, which Harvey can do for you.
bobsworth
77
24-03-2016 09:30 PM
01-11-2015 06:53 PM
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
jay030787
25-09-2015 01:38 AM
Quick Reply: pectel monitor owners with P8 management..... read on
