Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Remote not locking doors after changing battery
Old Jun 8, 2018 | 11:24 AM
beerenigma's Avatar
beerenigma
Default Remote not locking doors after changing battery
Hi
I've a 2004 Fiesta LX with only one key.
I changed the battery yesterday and since then the remote unlock doesn't work. The key will open the door and start the car, so Im guessing the chip is still ok - its never given problems unlocking remotely before.
I've tried loads of online suggestions, key to II then I four times then hold the unlock etc but all to no avail. I get a beep which I believe indicates learning mode, but that's as far as I get.
Anyone got any other ideas please
Thanks
Old Jun 8, 2018 | 12:35 PM
haz87's Avatar
haz87
Definitely swapped battery like for like?
Old Jun 8, 2018 | 02:17 PM
beerenigma's Avatar
beerenigma
Yep, CR2032 and just to make double sure, just purchased a new duracell 2032 and same result, get the beep after four turns, but press the unlock button and nothing happens,
Old Jun 8, 2018 | 06:24 PM
martysmartie's Avatar
martysmartie
The partnership has been lost. You need to pair it via learning mode.
Martin
Old Jun 8, 2018 | 07:17 PM
beerenigma's Avatar
beerenigma
Martin
I have the beep for learning mode but nothing when I press the unlock button
Old Jun 11, 2018 | 04:16 PM
martysmartie
In that case, I would suggest the remote to be faulty.
Have you checked to make sure nothing has been disturbed inside?
Martin
Old Jun 12, 2018 | 11:30 AM
beerenigma's Avatar
beerenigma
Martin
Yep its exactly as it was when it was working seconds earlier. Literally opened it, carefully lifted the batter and replaced it. I believe they lose settings if the battery is out for 20 seconds and that may have been the case as I was being careful, but then you are supposed to be able to re programme it in learning mode which isn't working. Chip working as the key starts the car and opens the doors, just not the remote locking.
Old Sep 13, 2018 | 10:54 AM
hairyford's Avatar
hairyford
Originally Posted by beerenigma
Hi
Thanks
when programming the key,u know when u turn the key 4 times till u hear the bleep,press lock button on fob,dont u have to turn the key again 4 times to lock down the memory,thats what ive done with mine
kdavie86
Fiesta's Other !
Jun 8, 2014 07:50 AM
Kammy1
Ford Focus ST
Jan 14, 2014 01:41 PM
Zahid Khokhar
Ford Focus Diesel
May 15, 2013 09:41 PM
maxiboy1
Sep 26, 2011 07:44 PM
fiesta wrs
Feb 15, 2011 08:10 PM
