Ford Fiesta This forum is for discussion of all things pertaining to the Ford Fiesta Range of cars.
Remote not locking doors after changing battery
Old 08-06-2018, 11:24 AM
beerenigma
beerenigma's Avatar
Default Remote not locking doors after changing battery
Hi
I've a 2004 Fiesta LX with only one key.
I changed the battery yesterday and since then the remote unlock doesn't work. The key will open the door and start the car, so Im guessing the chip is still ok - its never given problems unlocking remotely before.
I've tried loads of online suggestions, key to II then I four times then hold the unlock etc but all to no avail. I get a beep which I believe indicates learning mode, but that's as far as I get.
Anyone got any other ideas please
Thanks
Old 08-06-2018, 12:35 PM
haz87
haz87's Avatar
Definitely swapped battery like for like?
Old 08-06-2018, 02:17 PM
beerenigma
beerenigma's Avatar
Yep, CR2032 and just to make double sure, just purchased a new duracell 2032 and same result, get the beep after four turns, but press the unlock button and nothing happens,
Old 08-06-2018, 06:24 PM
martysmartie
martysmartie's Avatar
The partnership has been lost. You need to pair it via learning mode.
Martin
Old 08-06-2018, 07:17 PM
beerenigma
beerenigma's Avatar
Martin
I have the beep for learning mode but nothing when I press the unlock button
Old 11-06-2018, 04:16 PM
martysmartie
In that case, I would suggest the remote to be faulty.
Have you checked to make sure nothing has been disturbed inside?
Martin
Old 12-06-2018, 11:30 AM
beerenigma
beerenigma's Avatar
Martin
Yep its exactly as it was when it was working seconds earlier. Literally opened it, carefully lifted the batter and replaced it. I believe they lose settings if the battery is out for 20 seconds and that may have been the case as I was being careful, but then you are supposed to be able to re programme it in learning mode which isn't working. Chip working as the key starts the car and opens the doors, just not the remote locking.
Old 13-09-2018, 10:54 AM
hairyford
hairyford's Avatar
Originally Posted by beerenigma
Hi
Thanks
when programming the key,u know when u turn the key 4 times till u hear the bleep,press lock button on fob,dont u have to turn the key again 4 times to lock down the memory,thats what ive done with mine
Kammy1
Ford Focus ST
14-01-2014 01:41 PM
Zahid Khokhar
Ford Focus Diesel
15-05-2013 09:41 PM
maxiboy1
26-09-2011 07:44 PM
fiesta wrs
15-02-2011 08:10 PM
Quick Reply: Remote not locking doors after changing battery
