Starter wire from ignition amp value
Old May 12, 2018 | 12:38 PM
RIB1122's Avatar
RIB1122
Default Starter wire from ignition amp value
does anyone know roughly how many amps come from the starter wire on the crank position and goes to the solenoid on the starter?
Is a pretty hefty cable
Is a sierra 4x4 cosworth
Old May 12, 2018 | 08:30 PM
big_wasa's Avatar
big_wasa
I asked the question years ago and got no reply so I measured it with a basic metre and got around 10a but with a much larger initial spike.
Old May 13, 2018 | 09:39 AM
RIB1122's Avatar
RIB1122
Old May 13, 2018 | 04:33 PM
martysmartie's Avatar
martysmartie
As said an ammeter/DMM would confirm.
Martin
Old May 13, 2018 | 09:33 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Main wire from battery is about 120 Amp when cranking, typical starter is about 1.4 kW so fed with 12 Volts would see about 116 Amp. I think the wire form the ignition switch to the solenoid is about 6 square mm (2.75 mm diameter) so it can carry about 47 Amps.
Old May 13, 2018 | 09:38 PM
martysmartie
Originally Posted by JFB Tech
About 120 Amp when cranking, typical starter is about 1.4 kW so fed with 12 Volts would see about 116 Amp.
Your talking about the starter, the solenoid is much smaller.
Martin
Old May 15, 2018 | 08:21 PM
stevieturbo's Avatar
stevieturbo
C**t
The OP is unclear about which bit he is asking.
Old May 24, 2018 | 06:07 PM
landaqmabba's Avatar
landaqmabba
if you re talking about starter it s high current my amm metre (hall effect) reads to 30a and it's maxed out on "click" then drops to around 20ish amps on a small 1.2l clio so a higher compression engie or bigger cc more current.
on a 1.8l endura diesel it stays maxed out all the time selfstarter spins.
if it's for the starting solenoid it's lower current 10 ish or whereabouts i think, but never tested that
thetrudon
Jun 6, 2015 10:08 PM
robbo9006
Nov 26, 2011 04:17 AM
TrevCos
12
Feb 12, 2009 04:31 PM
abdr500
37
Mar 1, 2006 05:44 PM
BillyCabrio
39
Sep 10, 2005 11:23 AM
