boost adjustment
Old Apr 11, 2005 | 10:14 PM
no grip's Avatar
no grip
Default boost adjustment
Can't get my one remaing brain cell around which way to adjust the actuator to increase boost! should it be shortened or lengthened?
Old Apr 11, 2005 | 10:29 PM
glenis's Avatar
glenis
dont reckon actuators adjust the boost... they just hold it...
could be wrong
Old Apr 11, 2005 | 10:34 PM
cossied's Avatar
cossied
Default boost
shorter more boost. ED
Old Apr 11, 2005 | 10:44 PM
glenis's Avatar
glenis
well what is bleed valve for then cossied ?
Old Apr 11, 2005 | 10:53 PM
no grip's Avatar
no grip
its so much easier than working it out!
i've got one of these adjustable boost gizzmos that can only increase boost - so the idea is to back the actuator off to min and let the thingy take over
are they wort the high cost - about a fiver?
Old Apr 12, 2005 | 02:51 PM
cossied's Avatar
cossied
Default boost
I think a bleed valve is used to fool the actuator in to giving more boost.
Old Apr 12, 2005 | 05:25 PM
Moonie's Avatar
Moonie
The bleed valve bleeds off a small ammount of air/pressure so the actuator is seeing less pressure than is present in the intake system. The more air that is allowed to escape (bleed off) will result in the actuator remaining closed for longer until enough pressure has built up to overcome the spring pressure in the actuator.
Old Apr 12, 2005 | 05:39 PM
cossied's Avatar
cossied
Default boost
straight from the horses mouth
Shorten rod one half turn for every 0.02 bar of pressure below that specified.
Volume 2 of ford cosworth manual section 23-16[/img]
cossied's Avatar
cossied
Default boost
Old Apr 12, 2005 | 06:59 PM
Rs1's Avatar
Rs1
Aye you want to shorten for more boost but i wouldnt knock the boost all the way down then readjust with a boost controller. You want some pre load on the actautor or you'll end up with a slightly more laggier response. Set the boost manually slighlty below the point where your gonna have the controller take over.
I.E Pre load it to 1 bar then set the low boost on the controller to 1.1.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Fezman1
Oct 2, 2015 01:22 PM
Russ Payne
Sep 25, 2015 08:29 PM
