where is cold start valve
Old Apr 9, 2005 | 08:15 AM
glenis's Avatar
glenis
Default where is cold start valve
where is it on Efi inlet manifold ?
Old Apr 9, 2005 | 11:41 AM
Moonie's Avatar
Moonie
In the middle underneath the inlet manifold, it has a blue plug
Old Apr 9, 2005 | 02:54 PM
JesseT's Avatar
JesseT
There is none.
Old Apr 9, 2005 | 03:35 PM
Moonie's Avatar
Moonie
I thought glenis ment the cold start injector?
Old Apr 9, 2005 | 03:36 PM
glenis's Avatar
glenis
i have been told to replace cold start valve ?!?!
or whatever it is ?!
Old Apr 9, 2005 | 04:26 PM
GrimmeRS2K's Avatar
GrimmeRS2K
yeah if u had mfi system, but i dont think efi have one controlled by the ecu i reckon
Old Apr 9, 2005 | 04:32 PM
glenis's Avatar
glenis
what about the cold start injector then ?
underneath, blue plug as moonie said ?
Old Apr 9, 2005 | 04:34 PM
GrimmeRS2K's Avatar
GrimmeRS2K
no the blue one is on mfi like my car still mfi system, deffo think think yours is ecu controlled,
i would look else where for your miss fire, try the basics first and check wires.
Old Apr 9, 2005 | 04:47 PM
glenis's Avatar
glenis
it runs rough as fuk for about first 5 minutes...
replaced plugs the other day, leads are ok, as are cap and rotor arm...
Old Apr 9, 2005 | 04:49 PM
GrimmeRS2K's Avatar
GrimmeRS2K
fuel filter?, could be a sensor or something, sorry dont know much about efi,
Old Apr 9, 2005 | 07:31 PM
Moonie's Avatar
Moonie
Ahh read it properly now "EFI"
The EFI system has an idle speed control valve (controlled by the ecu) that varies the ammount of air entering the engine when the throttle is shut. If it running poor from cold it could be the coolant temp sensor goving the ecu the wrong reading therefore the ecu will be injecting the wrond ammount of fuel. The idle speed control valve could also cause your fault, its located on the left hand side of the manifold (looking from the front). Best bet would be to remove it and give it a clean out with some carb cleaner, see if the starting improves.
Old Apr 9, 2005 | 07:46 PM
glenis's Avatar
glenis
Moonie mate, where is it on this picture please ?!
Old Apr 9, 2005 | 10:56 PM
ON-UJAH's Avatar
ON-UJAH
EFI has no cold start valve.
ISCV ist the silver tube with a black hose running from it to the charge carrier.
Water temp sender is on the inlet manifold, at the back, underneath. It connects with a plug from the plastic casing, just like the injector plugs come out of.
Air Charge Temp is on the inlet, just visible on the right of your pic.
Check all vacuum hoses, MAP, plugs and leads too.
muffster
13
Sep 3, 2015 09:40 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Sultzi
12
Aug 16, 2015 01:08 PM
Archiejay
Aug 12, 2015 12:07 PM
Red_bull
Aug 9, 2015 08:34 AM
