ZVH cold starting problems
Old Apr 8, 2005 | 09:02 PM
glenis's Avatar
glenis
Default ZVH cold starting problems
hi,
what could be causing a ZVH to start like a bag of sh!t in the mornings...
it idles about 400 rpm for about 10 minutes, then after gentle revving and warming up the revs get higher to about normal of 1000-1100rrpm...
is it misfiring ? or running on 2 or 3 cylinders
why is this happening everytime ? its only after its cooled right down, like overnight etc....
can some help! thanks!
Old Apr 8, 2005 | 11:25 PM
GrimmeRS2K's Avatar
GrimmeRS2K
what injection system u running mfi/efi?, i would try the cold start valve mate
Old Apr 9, 2005 | 08:03 AM
glenis's Avatar
glenis
it is running Efi ...
where would the cold start valve be located, as i know where it is on MFi....
what should i do replace it, you mean ?
Old Apr 9, 2005 | 11:29 AM
matts1's Avatar
matts1
My old S1 was the same, wouldn't hold it's own when cold and would miss, I found that if you started it without touching the gas pedal it would start better, but as said, cold start valve, replace it
Old Apr 10, 2005 | 08:53 AM
sammy's Avatar
sammy
the sensor is on the bottom of the inlet manifold, blue plug i think. when its hot & you disconnect the iscv, do the revs drop to about 700rpm? (the base idle setting), also make sure the throttle body is clean,
Old Apr 10, 2005 | 08:56 AM
glenis's Avatar
glenis
what sensor ?
been told EFI does not have cold start valve...
ISCV is what could be doing it, or throttle body...
Old Apr 10, 2005 | 10:13 AM
Rs1's Avatar
Rs1
Thermotime switch. As above said blue in colour, under the inlet manifold. And your correct efi doesnt have a seperate cold start valve like the mfi. Its all ecu controlled.
Old Apr 10, 2005 | 11:49 AM
glenis's Avatar
glenis
what about it ? clean it or replace it completely ?
Old Apr 10, 2005 | 12:39 PM
sammy's Avatar
sammy
i would personally just replace it, but it can be tested, ill presume your using fiesta turbo management, at 0 degrees C, it should read 88000-102000 ohms, at 80 deg C, 3000-4500 ohms, this is measured with plug disconnected across the 2 pins, with the plug connected, ignition on & at 0 deg C, you should measure 3.8 volts approx, & at 80 deg C, 0.7 approx these readings are off autodata so sorry if there wrong
Old Apr 10, 2005 | 12:50 PM
glenis's Avatar
glenis
what is the exact component name for when i order one tomorrow at my local FORDs
its name is thermotime switch ?! part number ?
cheers mate
Old Apr 10, 2005 | 12:52 PM
glenis's Avatar
glenis
and that will cure it completely ?
Old Apr 10, 2005 | 01:18 PM
sammy's Avatar
sammy
E.C.T, engine coolant temp sensor (not sender), i cant say whether it will fix it, but its the first thing i would try, did you try disconnecting the iscv when hot to see if the revs drop? (just to check its working really)
Old Apr 10, 2005 | 01:19 PM
glenis's Avatar
glenis
what does the ECT do exactly ?
when hot and cold
Old Apr 11, 2005 | 04:59 PM
Rs1's Avatar
Rs1
Tells the ecu the engine coolant temp throughout warmup procedure to provide correct fuelling.Very basic explanation mind
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Archiejay
Aug 12, 2015 12:07 PM
