Weird idle issue that goes after being driven/boosted (2.0 zetec turbo
Old Sep 13, 2014 | 02:41 PM
Richie15's Avatar
Richie15
Default Weird idle issue that goes after being driven/boosted (2.0 zetec turbo
Hi all this issue seems to have got worse since the cars been off the road to fit new gearbox,
The problem is when it's first fired up it doesn't like to be revved, it sounds as if it's running on 3 cylinders it's quite rough and pops and bangs if revved and is spluttery and hesitant, however...if I take it for a drive and get it to boost up it cures the problem and it will rev smooth and responsive from then on!?
The engine is a 2.0 silvertop Zetec E (late model)
Fully rebuild with forged pistons rods ect
Focus Rs turbo running 1 bar direct atm
EFI HO inlet manifold
omex 600 ecu
3bar map sensor
New coilpack, leads, plugs,
New ICV
haven't yet tried tps
New coolant temp sensor
Omex air temp sensor
I will be doing a compression test once I get my hands on a gauge
The engine since I've built it is still on a running in map untill I covered 1000 miles and has always had a hunting on idle (the mapper said he couldn't work out what was causing it but it was mapping and running fine other than that) I cannot eliminate this I'm hoping that once remapped (from a cold start) it will cure this, as the engine was hot by the time he got it running nice.
Any help/advice will be much appreciated, thanks.
Old Sep 13, 2014 | 02:50 PM
t230's Avatar
t230
i had this with incorrect MAP sensor or may be unplugged or pipe work may be leaking ......i also had it 'as if ' itt were running on 3 cylinders becuase of a torx bit having been dropped in oil filler capped thus smashing straight thru head...for sum reason gave me 3 cylinder effect
jus go over and double check everything
Old Sep 13, 2014 | 03:56 PM
studabear's Avatar
studabear
have you got a afr gauge fitted?
Old Sep 13, 2014 | 04:12 PM
Richie15's Avatar
Richie15
Sorry but what's an afr gauge ?
I've checked everything to do with map sensor plug is fine vaccum is fine no air leaks at all
Really getting to me now lol
Cheers for the help
Old Sep 13, 2014 | 04:30 PM
studabear's Avatar
studabear
Air fuel ratio, you need a wideband lambda sensor in the exhaust too
Old Sep 13, 2014 | 05:25 PM
Richie15's Avatar
Richie15
No haven't got one of them fitted, it was mapped with a wideband fitted then taken off afterwards as it was the guys who mapped it he didn't say I needed to re fit one I'll invest in one of those for the remap for sure
Old Sep 27, 2014 | 07:01 AM
Churtz's Avatar
Churtz
Compression test first. From cold then hot. See what's changing. Sounds like somethings not right there to me.
Old Sep 28, 2014 | 09:55 PM
stevieturbo's Avatar
stevieturbo
C**t
Whilst it may be partly mechanical, just sounds like a mapping issue for the most part.
And put new plugs in it.
Old Sep 29, 2014 | 05:27 PM
Churtz's Avatar
Churtz
I hear what you're saying about mapping, but mapping wouldn't have got worse since it's been off the road.
Old Sep 29, 2014 | 05:53 PM
stevieturbo
C**t
yes, but you also said it is still a running in map, you never gave how much history as to when it ran perfectly for.
You said it had been laid up, and possibly now with some short start stop scenarios which could lead to plugs either flooding or fouling if the cold start wasnt great. Which in turn could lead to it going off cylinders.
Hence...get mapping checked, and fit new plugs.
yes there may be other issues...but without some ecu information in front of me, or the car in front of me....rather difficult to diagnose.
Old Sep 29, 2014 | 05:58 PM
Richie15's Avatar
Richie15
Thanks for the help, I will be taking it for mapping soon as it's on the road just didn't want to take it there to be mapped an fine out something's up that I could have fixed beforehand
Thanks
robnock
21
May 13, 2019 05:29 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
Cameron
14
Aug 9, 2015 06:28 AM
turbobill
Aug 1, 2015 08:55 PM
