Did someone find a new age starter to fit the cossy 4x4 ?
Old Jul 16, 2014 | 11:41 AM
markk's Avatar
markk
Default Did someone find a new age starter to fit the cossy 4x4 ?
As above, done a quick search and didnt come uo with a lot,
I need a starter to fit my escort - usual YB/MT75 starter,
Thought I had one, but it must be a 2wd unit.
Old Jul 16, 2014 | 01:00 PM
chris cdti's Avatar
chris cdti
in sure i saw someone going on about the 1.8 td starter motor fitting the cosworth engine.
Old Jul 16, 2014 | 03:04 PM
A tranny connect one will fit but i think you have to drill one of the holes in the startrer motor. On a tranny connecy starter 3 bolt screw into the starter but i think on the cossie 4x4 box one or more of the bolts screw into the bell housing.
Old Jul 16, 2014 | 03:19 PM
markk's Avatar
markk
Like this one
http://www.ebay.co.uk/itm/S1627-NEW-...item1e8dbb719c
Old Jul 19, 2014 | 02:55 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
diesel starters are not for 4x4, only T5 boxes
Old Jul 19, 2014 | 03:03 PM
doga-ot's Avatar
doga-ot
I may have 1 if u need i'll have a look in next hour
Old Jul 19, 2014 | 04:30 PM
markk's Avatar
markk
I thought this was the case,
Old Jul 19, 2014 | 05:32 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
There was a thread on this a fee weeks back and one of the members said he has one on his Escos and 2wd. I'll try and find it.
Old Jul 19, 2014 | 05:35 PM
DixieTheKid
Pick-up P100 Power!
https://passionford.com/forum/ford-s...my-3-door.html
Old Jul 20, 2014 | 03:48 PM
Yeh I remembered the correct info.Thats not like me cause my memory is crap.
Old Jul 20, 2014 | 05:46 PM
Sonic Boom's Avatar
Sonic Boom
Was about to post my thread up but i've ben beaten to it, looks like it even fits ERST's too.
Rich
Old Jul 20, 2014 | 06:55 PM
whizzisat114's Avatar
whizzisat114
iirc we had a play wiith one of these to fit to a 4x4 and it fouled the oil filter so we rotated the solenoid clockwise to miss but then the solenoid covered the centre mounting hole so we passed a 8mm bolt through from the gearbox end and fitted a nylock nut and washer . does seem to turn engine over with more torque but a little slower.
we now have one fitted to a 4x4 with a wrc winged sump and breather system with no problems
David
Old Aug 14, 2014 | 11:37 PM
markk's Avatar
markk
Further to this, bought a connect starter, 2006 1.8 Diesel, different bolt centres, would not line up to the box.
Anyone any part numbers that fit the 4x4?
Old Aug 15, 2014 | 05:53 AM
AJC's Avatar
AJC
With regards to people saying thats it won't fit the 4x4 cossie
whats the actual difference between a 2wd and 4x4 starter, i always thought it was just the length, and size of body, the holes are all the same? i hope im not wrong, i have a connect starter motor on my saff 2wd and my escort turbo, and im 95% sure there is also one on my escort cos.
The escort cossie only uses 2 bolts but that is because the big wing sump is in the way for one of them
Old Aug 15, 2014 | 09:33 AM
markk's Avatar
markk
I can see it fitting the 2wd cars, just not the 4wd cars.
I need to come and look at your escort Andy
Old Aug 15, 2014 | 11:44 AM
M K's Avatar
M K
I have this 1 fitted
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
kosienutter
31
Aug 22, 2015 09:55 AM
cossie4x4
Aug 14, 2015 06:29 PM
jack-rs500
Aug 5, 2015 07:07 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
