03 tdci black smoke problem
Old Aug 19, 2013 | 06:23 PM
shcubasteve's Avatar
shcubasteve
Unhappy 03 tdci black smoke problem
Hi I have an 03 130 tdci and has started to smoke on pull off until 2500 revs thick cloud then sometimes goes to grey, I have replaced the fuel filter and air filter and cleaned the egr and inlet manifold. and today had it plugged in to see if there are any fault codes and none at all showed so am stumped now what it could be I have seen some similar threads but can not get to the bottom of it so any suggestions would be great ...thanks steve
Old Aug 19, 2013 | 06:32 PM
GVK.'s Avatar
GVK.
Check the intercooler to EGR boost pipe, these can split.
Old Aug 19, 2013 | 07:37 PM
cossiejay's Avatar
cossiejay
sticking turbo vanes
Old Aug 19, 2013 | 10:18 PM
shcubasteve
i have checked both pipes from intercooler and egr side is fairly new as well as I've reaced it thanks GVK
Old Aug 19, 2013 | 10:20 PM
shcubasteve
What would be best thing for sticking turbo vanes can they be cleaned easy??
Old Aug 20, 2013 | 01:52 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
You can get cleaners but they aren't really that effective IMO.
You say you've cleaned the EGR, but is it actually working? Cleaning is no guarentee that it's ok. Blank it off and see if the issue remains.
http://www.ebay.co.uk/itm/STAINLESS-...-/161059547137
Old Aug 20, 2013 | 02:08 PM
shcubasteve
have blanked off the vacuum yesterday and does not seem to have made much difference
thanks dan
Old Aug 20, 2013 | 03:49 PM
shcubasteve
Default egr plate
Have just ordered a blanking plate so will wait and see if this does the trick, also spoke to a diesel specialist and he has said the same so hopefully this will do the trick, and will post if it does...
thanks for the help everyone
Old Aug 20, 2013 | 04:10 PM
fordcozyjohn's Avatar
fordcozyjohn
hi dus it smoke on tick over ?
mk5/6 escortt cosworth van body kit for sale
Old Aug 20, 2013 | 04:29 PM
seanylayke's Avatar
seanylayke
Default mondeo tdci 20 ltr
hi i have a mondeo tdci 20 ltr at first my 115 bhp mondeo cam sliped so i replaced the engine. only the bear engine was replaced 130 mondeo engine was put back in i have had all 4 injectors recond it will only rev too 2000 rpm turbo dont sound too heathly there black smoke can anyone help
Old Aug 20, 2013 | 04:34 PM
shcubasteve
no only when revved up john
Old Aug 20, 2013 | 04:38 PM
fordcozyjohn
is it white smoke ?
Old Aug 21, 2013 | 09:32 AM
DanW@FastFord
Spelling Club King!
Start your own thread, you're more likely to get replies. There are hundreds of different things it can be. You need to have it properly diagnosed by a specialst.
Old Aug 22, 2013 | 02:49 PM
shcubasteve
Default egr blank
Hi guys
fitted the EGR Blanking plate today and hey presto all sorted thanks for everyones input ....
Kyle Langford
27
Aug 5, 2019 07:54 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
nick8saff
Aug 16, 2015 05:35 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
