mk1 focus rs rear wheel bearing
Old Jan 14, 2013 | 08:22 PM
stevos's Avatar
stevos
Default mk1 focus rs rear wheel bearing
As above guys can you buy the bearing separate or do you need to buy the full hub.
Thanks steven.
Old Jan 14, 2013 | 08:28 PM
the_frozen_one's Avatar
the_frozen_one
Had plenty of normal mk1 focus bearings seperate, you must be able to get rs ones. If not from a stealership than from a factors. Don't be scared of QH bearings. Had a focus bearing from ford once, was in a QH box inside a ford box. Extra 20 quid for a branded box
focus 4x4's Avatar
focus 4x4
You can get the bearing separate .
Old Jan 14, 2013 | 08:46 PM
stevos's Avatar
stevos
can i get it from a motor factors or best go to ford
Old Jan 15, 2013 | 09:15 AM
lowman's Avatar
lowman
anyone knows if the "rs " bearing is a special one...or is it the same as from a say...2.0 litre...
Old Jan 13, 2015 | 10:21 AM
dared20's Avatar
dared20
Default Rear wheel bearing
Hi all,
I just got a standard rear wheel bearing to replace my noisy one, and guess what -it doesn't fit (even though the part no. is the same on the auto directory). Standard ID of the bearing is 28mm and mine is 35mm.
New hub and bearing unit from FORD is £369 (!!!) so I continued to try replace mine by buying a separate bearing.
I tried pressing the bearing off, with no luck. Went up to 10T of force, and then heated the unit up to about 150degC, but still it did not budge. I can only assume that they require some custom tools to replace them. The space on the outside bearing race to press a new one in is also only about 1.5mm, so I would need to make a custom ring to press the new one on again...
Has anyone done this in the past to avoid having to lump out £369...?
Thanks!
Old Jan 15, 2015 | 05:14 PM
JamboRS's Avatar
JamboRS
focus rs 1672
carpartsexpress or demon performance centre are your best bet mate
Old Jan 20, 2015 | 07:41 PM
blan77's Avatar
blan77
Hate to disappoint ,but you need to visit your local ford dealer and hand over lots of cash ,these units are sealed some way, I tried myself to strip the races out .....with a massive fail ...I've never been beaten on any bearing changes before ,and I've changed bearings up to 3ft in diameter as a job ..I always change things like this in pair so had to stump up a sight load of cash !!!!!!!
Old Jan 20, 2015 | 08:01 PM
Fezman1's Avatar
Fezman1
Demon performance centre do the hub for £85 and abs ring for £25
Car parts express hub kit is £120 - this may include abs ring & nut, but not sure.
Give either a ring and they will sort you out.
jonfoc's Avatar
jonfoc
Built into the hub. Over on RSOC many have tried and all failed to find a cheaper replacement
Old Jan 25, 2015 | 03:31 PM
dared20's Avatar
dared20
Ok thanks guys
Just another note, there was an SKF stamp on the casting of the hub, so I assume they made the whole unit. Your comments confirms that it's impossible the change!
Demon bearing it is, I hope it lasts...
malkiemac3579
Jul 14, 2017 12:10 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
muz
Aug 1, 2015 06:48 AM
