ST200 running problem
Old Nov 27, 2012 | 07:52 AM
3dr cossie's Avatar
3dr cossie
Default ST200 running problem
Hi,
i've owned a st200 estate for over 4 years now, but its developed a intermittant fault and i have no idea what it could be.
the fault is that when i'm driving along at 70 on the motorway, the car will cut out for a split second, ie, the radio goes off and i get the ignition lights on the dash. if it wasn't for the radio going off, you wouldn't even notice as its that quick.
also if i'm accelerating quite hard it will do the same thing at the higher rev range.
i had a none ford alternator fitted about 2 years ago and i've had this fault for over a year now, could the 2 be related as i've heard st200's have a different regulator to other v6's?
any help would be great
cheers Matthew
Old Nov 27, 2012 | 03:59 PM
Cosnada's Avatar
Cosnada
Had a similar issue on Mondy tdci - it was a loose + battery terminal. Simple but cured the problem that occured twice months appart.
Old Nov 28, 2012 | 12:20 PM
3dr cossie's Avatar
3dr cossie
cheers, will give it a check tonight
cheers Matthew
Old Nov 29, 2012 | 06:37 PM
bookwyse's Avatar
bookwyse
They are known for this and it is usually a loose connection in the instrument cluster that causes it. Had it on two of my four 200's and couldn't believe it when we finally located the fault.
Old Feb 8, 2013 | 09:47 AM
3dr cossie's Avatar
3dr cossie
so you just checked the plug on the back of the clocks, eg speedo and rev counter?
cheers Matthew
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
blakey100
Aug 4, 2015 08:17 PM
