Zetec turbo build ( first engine build)
Old Nov 20, 2012 | 07:09 PM
bagginsRSturbo's Avatar
bagginsRSturbo
Default Zetec turbo build ( first engine build)
Hi,
I'm looking at building a zetec turbo and was wondering if any one could give a list of what parts are needed, and any general advice as it is my first engine build
Old Nov 20, 2012 | 07:10 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Use the search bar mate, endless threads about this.
https://passionford.com/forum/ford-e...onversion.html
That's a good read.
Old Nov 20, 2012 | 07:31 PM
bagginsRSturbo
Cheers, looks like a good read
Old Nov 20, 2012 | 07:47 PM
crazycage's Avatar
crazycage
Thumbs down
Originally Posted by bagginsRSturbo
Hi,
a target hp would help and what the car will be used for .
Old Nov 20, 2012 | 07:51 PM
bagginsRSturbo
Something sensible like about 300bhp andits going in a fiesta
Old Nov 20, 2012 | 07:56 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Mk1/2/3/4/5/6? Will all vary as obviously huge weight differences.
Old Nov 20, 2012 | 07:59 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Oh, and 300bhp in a mk1/2 won't be sensible at all, hooniganism at it's finest
bagginsRSturbo
Sorry forgot to put its a mk4 ( I know lol but it was free )
Old Nov 20, 2012 | 08:05 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Nowt wrong with a mk4, I had one as my first car, dropped it 60mm on some Capri Lasers, stuck a cone filter on it and loved it before promptly stacking it in the side of a van.
Pretty sure the principle is the same in terms of mounting a 2.0 in it though, which that thread shows you.
crazycage's Avatar
crazycage
keep it simple and it will be reliable.
id do like this because you will always want more.
2.0l blacktop engine
forged pistons and steel rods with a comp ratio of around 8-1.
bog standard head and cams but with some uprated valve springs
standard head bolts and gaskets pulleys and flywheel
standard sump
you could keep the standard focus/ mondeo inlet to a point or fit a better one
custom exhaust manifold
turbo of your choice but id go for a t34 there cheap and good upto 380hp
with it being a fiesta fit a swirle pot in the boot use the in tank pump to feed it then a 044 pump to the fuel rail.
injectors id go for vxr ones good for 350hp and there only about Ł80 new.(bigger if you want more power)
gearbox
id use a focus rs box with atb diff
clutch id use the focus rs one
custom shafts
management of your choice.
Old Nov 20, 2012 | 08:08 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
what is your budget?
just stripping my zetec turbo, the costs will spiral if you don't budget and plan ahead big time.
what management are you going for?
what gearbox are you using, as this will determine clutch.
300bhp is quite a lot, i'm not sure what mine has done power wise, but just short of 2BAR through a gt30 must be heading towards 400bhp and is too much for anything other than a strip or trackdays.
Old Nov 20, 2012 | 08:09 PM
bagginsRSturbo
standard sump
gearbox
custom shafts
What sort of piston should I use as its seems to vary what people use, what sort of cash am I looking at ?
Old Nov 20, 2012 | 08:11 PM
bagginsRSturbo
I just can't Stand the front end of them, but I've got a mk5 zs front end so might swap it over
Old Nov 20, 2012 | 08:14 PM
crazycage's Avatar
crazycage
i have CP pistons in my new engine ,there about Ł550 a set
my last engine had wossner pistons and it done 35k on them.
bagginsRSturbo
Haven't decided on a budget yet, how much should I allow as don't want to plow thousands into it just for a bit of fun
Old Nov 20, 2012 | 08:15 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
in my build i use wiseco piston, got them from the states with eagle rods, went for 86mm ones and had the bores opened up in a blacktop engine.
with shells and things, they were cheaper than over here, but i did get stung for import tax.
i'd plan on a grand for pistons and shells, Ł100 for boring maybe.
that will take over 500bhp without problems, oil pump will be the next weak link though.
Old Nov 20, 2012 | 08:17 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
definitely decide on budget, a grand and a half in the engine alone, manifolds, injectors and a turbo and you're on Ł2500 pretty quick, management could be as little as Ł500.
clutch could be cheap, but again depends on box, frs are very strong, gary and myself used these at some point, but another Ł600 ish for one, plus fitting parts.
Old Nov 20, 2012 | 08:18 PM
bagginsRSturbo
Is it best to put pistons in or use a decomp plate ( what sort of power can you safely have? )
Old Nov 20, 2012 | 08:20 PM
bagginsRSturbo
Oh that's more then I thought it would be, but I haven't looked into costs as yet
Old Nov 20, 2012 | 08:21 PM
crazycage's Avatar
crazycage
if i were you i would just buy his engine .
Old Nov 20, 2012 | 08:22 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
sold mine already gary
will be gone next week, shame but it's more of a track car and that's too much to get into.
Old Nov 20, 2012 | 08:26 PM
crazycage's Avatar
crazycage
ahh right , good with the rest of it then mate.
Old Nov 20, 2012 | 08:46 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
cheers pal, thanks for all the things you've helped me with along the way though.
Billy_RS
16
Oct 11, 2025 09:41 PM
Chopshop85
Aug 17, 2015 06:38 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
