bmw e60 wheel bearing change
Old Nov 17, 2012 | 01:15 PM
mk1turboestate's Avatar
mk1turboestate
Default bmw e60 wheel bearing change
just had the mot done on the car and have been told the o/s front bearing has a little play in it, has anyone done this job? how easy is it,
Old Nov 17, 2012 | 04:03 PM
j6kyt's Avatar
j6kyt
easy! i mean really easy
Old Nov 17, 2012 | 04:29 PM
mk1turboestate
how is it done?is it a hub swap? the bearing kits iv seen seem to have part of the hub
Old Nov 17, 2012 | 06:42 PM
mk1turboestate
bump for the night time
Old Nov 17, 2012 | 07:36 PM
jamie's's Avatar
jamie's
wheel, disc and caliper off, then just undo the hub nut, full flange with bearing pulls off,
then just refit new 1, 10-15 min job
Old Nov 18, 2012 | 06:46 PM
Brendan's Avatar
Brendan
struggling with reality
If there are ant probs getting the bearings out PM me and you can use my press! I will be away thursday pm to saturday morning! so don't ask then!
Old Nov 18, 2012 | 06:54 PM
jamie's's Avatar
jamie's
fronts usualy come in the hub flange, so no need to press it out/in
just pull the old 1 off then throw away, new 1 just slides in complete
Old Nov 18, 2012 | 09:31 PM
mk1turboestate
cheers lads. the one iv seen is already in the hub so it looks as easy as you say
Old Nov 19, 2012 | 06:45 PM
furry's Avatar
furry
DECODING JIBBA JABBA!!
Bought mine from GSF on Friday and will be doing it the weekend.
Old Jan 14, 2013 | 09:05 AM
furry's Avatar
furry
the E60 doesn't have a hub nut, the bearing/flange bolts on from behind with 4 bolts.
3 of the bolts are easy to get to but the 4 is behind the shocker which needs to be removed from the hub. to do this the lower arm needs to be seperated from the hub to allow the hub to come down enough for clearance. book time is 1.45hrs and from recent experience not the hardest bearing to do but certainly not the easiest.
Old Jan 14, 2013 | 08:13 PM
jamie's's Avatar
jamie's
ah well you learn something new everyday eh?
did you go looking for a 2 month old thread delibrately just to pick a hole in it?
i'm sure the guys already done it by now, but thanks for letting us know anyhow
Old Jan 15, 2013 | 10:38 AM
furry's Avatar
furry
no but if it means that it stops someone thinking it's a 20mins job after reading incorrect information i'm certainly going to correct it.
if you can't take being corrected make sure the info you put up is correct when you post.
Old Oct 27, 2015 | 08:51 PM
Caladan's Avatar
Caladan
I totally agree. This is not a 10 minutes job. If it was - I would have done it a long time ago. I have two new bearings but no time for replacing them.
Old Oct 27, 2015 | 09:02 PM
Your on a ford forum and your first post is about a bmw wheel bearing.
Old Oct 27, 2015 | 11:02 PM
Caladan's Avatar
Caladan
You're.
Old Oct 29, 2015 | 11:21 AM
gcfcos's Avatar
gcfcos
Well said that man
Old Oct 29, 2015 | 05:07 PM
Originally Posted by Caladan
You're.
Yerrrrp.
malkiemac3579
Jul 14, 2017 12:10 PM
cos elle
Sep 1, 2015 06:48 PM
cameron2
Aug 25, 2015 07:18 AM
muz
Aug 1, 2015 06:48 AM
