What supercharger is the loudest?
Old Oct 28, 2012 | 06:44 PM
StephTell's Avatar
StephTell
Default What supercharger is the loudest?
Odd question but what type of superchargers produces the loudest whining noise and what causes it to whine and what makes the whining worse?
Thanks!
Old Oct 28, 2012 | 06:55 PM
P_is_for_Paul's Avatar
P_is_for_Paul
Coldo loves seamen
Supercharger on my cooper S was pretty loud after I put an alta induction kit on it.
Old Oct 28, 2012 | 07:09 PM
rs_traynor's Avatar
rs_traynor
stage4 2wd cosworth
The charger on my focus is mega loud its a powerworks
Old Oct 28, 2012 | 07:58 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
It's the teeth that make it whine, they're straight cut on older stuff, whereas newer chargers use slightly helical thus reducing whine.
Can't beat a mega loud whine though
Old Oct 29, 2012 | 08:38 AM
StephTell's Avatar
StephTell
I need it for my other bike and I want it loud as hell LOL
Eaton M45's are cheap as chips over here, will that do the trick??
Old Oct 29, 2012 | 08:43 AM
m4tt274's Avatar
m4tt274
arent there two differant types of charger, like screw and ???
i have a total mind blank. One type is louder than the other i thought.
Though, as already said, i would imagine straight cut gears make them scream abit!
Old Oct 29, 2012 | 08:49 AM
StephTell's Avatar
StephTell
Screw and centrifugal I think...the screwtype is geardriven and should be loud then, especially with the smallest pulley on it to up the boost!
Need one to put on my hardtail mini-dragster GSXR1100 projectbike...
Old Oct 29, 2012 | 08:57 AM
StephTell's Avatar
StephTell
Isn't Will Pedley the go-to guy when it comes to superchargers on here? Is he still here or...?
Old Oct 29, 2012 | 09:43 AM
Beetlejuice's Avatar
Beetlejuice
Centrifugal chargers like Vortech and Rotrex are also geared.
Old Oct 29, 2012 | 09:56 AM
StephTell's Avatar
StephTell
Ah, ok!
Spoke to someone who has quite a bit of experience with Rotrex centrifugal chargers and he reckons they're crap at making boost low down wich is what I want.
I've three turbokits on the shelf so could easily bolt one of those on but I want boost low down AND a mechanical nightmare because I can lol
Old Oct 29, 2012 | 10:04 AM
Ima Racing's Avatar
Ima Racing
The one on the 98 JAG XJR V8 is the loudest i have heard!
Old Oct 29, 2012 | 10:17 AM
Beetlejuice
The sheer failure rate of Rotrex superchargers should be enough to put anyone off.
Old Oct 29, 2012 | 11:18 AM
SiZT's Avatar
SiZT
Roots are the loudest whilst on the throttle, twin-screws are loud'ish at idle, centrifugal's don't really make any noise.
P.S The noise is nothing to do with the gears
Old Oct 29, 2012 | 11:47 AM
stevieturbo's Avatar
stevieturbo
C**t
Originally Posted by StephTell
Ah, ok!
And Rootes types are crap at making power up top. Twin screws are better though.
Lets face it...motorbike engines arent renowned for using low rpm's all day.
So what exactly do you want from the engine package ?
Any PD style blower will be more complicated to install than a centrifugal.
Turbo would be easiest
Old Oct 29, 2012 | 12:01 PM
foxy06's Avatar
foxy06
I thought it was the belt myself???
Have an Eaton M62 waiting to go on!
Old Oct 29, 2012 | 02:46 PM
StephTell's Avatar
StephTell
A turbo would be too easy and I've done it before so therefor no fun.
Also, a whining supercharger fits the bill in the grandscheme of the bike I'm building.
The fact that bike engines aren't known for making a lot of power low down is completely irrelevant here.
I want as much low down grunt as possible within the boundaries I've set myself.
It would be rather silly not to use a type of charger that produces boost low down because motorbike engines aren't know for making power low down...
Besides: the engine is a 1226 cc engine with heads and cams specced for bottom/midrange grunt. That combined with short gearing and a supercharger will make for a bike that you don't have to rev the tits of to get it off the line!
Old Oct 29, 2012 | 05:11 PM
Caprigirl's Avatar
Caprigirl
Drift Queen
The Eaton on my DB7 isnt too noisy inside, however when the car passes you at full tilt you hear it from a fair distance............and it does sound good
Old Oct 29, 2012 | 06:43 PM
CoupeUK's Avatar
CoupeUK
YouTube Kenne Bell Cobra
Old Oct 29, 2012 | 07:58 PM
stevieturbo
C**t
Of course it is relevant. PD blowers offer power over a narrow rpm range. Motorbike engines to not operate over a narrow rpm range !
You will be limited by how much you can gear the blower to provide low rpm grunt, without it disintegrating at high rpm.
A PD blower is just a bad choice for a high rpm engine.
Old Oct 29, 2012 | 09:56 PM
Alg1k's Avatar
Alg1k
This is one of the loudest ive heard
Old Oct 29, 2012 | 10:27 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
The Eaton chargers are fitted with silencer ports to make them quieter, you can blank these off and port the charger to make a fair amount of extra noise
Old Oct 30, 2012 | 08:57 AM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Right, so what do you think creates the noise?
Old Oct 30, 2012 | 09:42 AM
stevieturbo
C**t
What nonsense
Old Oct 30, 2012 | 12:10 PM
SiZT's Avatar
SiZT
If it's the belt making a noise then it's too tight
It's the movement of air within the charger that makes the noise, hence why a PD s/c car with a stock airbox won't whine much but with a open air filter it'll be loud as hell.
Originally Posted by stevieturbo
What nonsense
Elaborate?
Steph, personally I'd be using a centrifugal. PD types would need work on the c/r and camshafts to create decent torque at the low-end, you would also be battling IAT temps alot with the amount you'd have to over-spin it. Use an Eaton if you're going Roots or something like a Lysholm if twin-screw
Old Oct 30, 2012 | 01:00 PM
stevieturbo
C**t
Clearly you've never heard many centrifugals then, including mine.
The gears create the majority of the noise. The belt drive can create some noise, but modern serpentine belts run pretty quiet. Even a cogged belt now can be pretty quiet.
They design belts to be as quiet as possible.
But gears, especially if straight cut, there is little way of quietening them down easily.
Old Oct 30, 2012 | 01:19 PM
SiZT's Avatar
SiZT
I'll concede that yours is noisy because of the gears, rotrex's (due to the way they are driven internally) aren't
Old Oct 30, 2012 | 07:42 PM
stevieturbo
C**t
The biggest 3 manufacturers, Procharger, Vortech and Paxton all use gears. Some helical cut, and some straight cut.
Rotrex would be a very small player in the market by comparison.
Likewise Powerdyne which uses a rubbish internal belt drive, although it would render it pretty quiet.
Old Oct 31, 2012 | 11:15 PM
Alg1k's Avatar
Alg1k
Old Nov 1, 2012 | 09:42 AM
Spiky's Avatar
Spiky
i run a rotrex on my 205 and it's silent
i know someone runninga eaton and it's stupid loud.
Old Nov 1, 2012 | 11:29 PM
Ginge's Avatar
Ginge
www.virtualseason.net
Whipple,Kenne Bell,they make proper loud chargers.
Whipple
Kenne Bell
Ginge
Old Nov 2, 2012 | 10:16 AM
stevieturbo
C**t
Whipple/Kenne Bell are both the same internals, ie Lysholm screw blowers.
I'd say a lot of the aftermarket stuff is made with making noise in mind too. The OEM would make them as silent as possible, whereas people retrofitting kits to their cars obviously want them to make noise.
Hell, Ive even seen people convert their accessory drive setups to a toothed belt to try and make a whine ! ( some with limited success lol )
Old Nov 2, 2012 | 10:40 AM
cossie891's Avatar
cossie891
Sorry but the vid with the blue car sounds fapping orrible
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
markk
Sep 9, 2015 08:11 AM
percybigun
28
Jun 21, 2005 04:17 PM
zvhrst
27
Apr 9, 2005 01:10 PM
scooby8272
24
Jul 23, 2004 12:03 AM
