coilpack headache
Old Aug 27, 2012 | 08:01 PM
tomoyb's Avatar
tomoyb
Default coilpack headache
have done the msd conversion on my 4x4 saph as per instruction
but the car fires up but it doesnt run right it sounds like the timings out/firing wrong
ive fitted new plugs and leads and its made no diffrance
it will backfire a little and doesnt want to rev above 2k(estimated as rev counter not working)
any idea?
only thing i can think of is faulty driver
bought that secondhand
Old Aug 27, 2012 | 08:05 PM
Cosnada's Avatar
Cosnada
Sounds like a phase issue - check you have the phase sensor plug / wires the correct way round.
Old Aug 27, 2012 | 08:25 PM
tomoyb's Avatar
tomoyb
cant the phase sensor plug only fit 1 way mate?
or do the wires have to be changed after fitting coilpack
also what does everyone do with old coil wiring?
Old Aug 27, 2012 | 08:33 PM
Cosnada's Avatar
Cosnada
Not sure what sort of wiring job you did. If it was just plug 'n' play then the plugs should be the correct way round if ya not touched them.
Coil wires - just hide them away, don't cut them off as you may wish to revert back to coil some day.
Old Aug 27, 2012 | 08:56 PM
costina's Avatar
costina
Live long and prosper!!
Could be a faulty ignition amp
Are you sure you connections to the ecu plug are correct?
Are the leads on correct?
Old Aug 27, 2012 | 09:10 PM
tomoyb's Avatar
tomoyb
Leads defo correct.coilpack and leads numbered.
Connections to ecu pins correct
Ignition amps worked spot on on car i took them off
I did have phase plug off but realised its still needed so put back on.i never removed rotararm.does that matter?
Old Aug 27, 2012 | 09:11 PM
tomoyb's Avatar
tomoyb
Thats what i done with old wiring i removed the black block thing that joined two green wires and taped them all up
Old Aug 27, 2012 | 09:41 PM
Cosnada's Avatar
Cosnada
Make sure the wires are correct in the connector then - 1st job I'd do mate. Might do well to buzz them out to the ecu - can remember the correct configuration at the moment.
Will have a look at a wiring diagram if I can find one tonight. Ya could just swap em over - won't hurt and it will eliminate it too from your investigations.
Old Aug 27, 2012 | 09:49 PM
langer's Avatar
langer
Am I rite in thinking your the boy from Edinburgh I got the box off? If you get stuck I can give you the conact details for a guy across here in Dunfermline who will certainly be able to fix it. His name is John Muir dunno if you've heard of him he used to have mv turbos across here. He's setting my car up for me very soon
Old Aug 27, 2012 | 10:01 PM
tomoyb's Avatar
tomoyb
I know john well bud.he set my cars up from 96-2002
Id heard hed started working again
Old Aug 27, 2012 | 10:26 PM
langer's Avatar
langer
He's never really stopped working just moved premesis and been doing allkinds after he built houses on the garage land. I'll pm you his direct email address rather than giving you his number dunno if he'd be ok with giving his number out. If you mail him tell him Darren give him you his email incase he wonders.
Old Aug 27, 2012 | 10:41 PM
whizzisat114's Avatar
whizzisat114
I've had a problem with coil packs labelled up wrong try writing down plug lead location then imagine turning sticker round 180° then put leads on.1 goes where 4 was 3 goes where 2 was 4 goes where 1was and 2 goes where 3 was .
Worth try anyhow
Old Aug 27, 2012 | 10:51 PM
Cosnada's Avatar
Cosnada
Phase sensor wiring is as follows:
Green/Yellow wire to pin 5 ecu and Blue wire in dizzy.
Black/Red wire to pin 23 ecu and Red wire in dizzy.
Check this out mate
Old Aug 28, 2012 | 07:19 AM
tomoyb's Avatar
tomoyb
Thanks il give it a go
I know john well mate pm me his number he wont mind ive known him since i was 16
Old Aug 28, 2012 | 03:23 PM
tomoyb's Avatar
tomoyb
Tried reversing phase sensor plug but it only goes 1 way.tried changing leads about aswell
Still no joy
Strange that it had spark at all 4 leads and start up but sounds like a subaru
Old Aug 28, 2012 | 03:39 PM
cossiestu's Avatar
cossiestu
Did you just unplug the phase sensor? Isn't there 2down there and you mixed them up?
Old Aug 28, 2012 | 03:55 PM
Smit's Avatar
Smit
The 60ft Launch King
Sure the map sensor is ok? This might be causing it to run rough and lumpy.
Old Aug 28, 2012 | 07:09 PM
tomoyb's Avatar
tomoyb
never mixed any plugs up i just took the phase sensor one off and put back on again
map sensor is fine,car ran perfect before removing coil and going wastedspark
ive unplugged one ign amp and it fired up on 2 cylinders as it should,turned car off and unplugged that one and put other back in,cranked it and wouldnt start on two
so i then tried the plug that fired 2 on the amp that never and it fired on 2
tried this again with other plug on both amps and wouldnt start,so id of thought one plug isnt getting what it needs to fire
but i cranked over with plugs out and they all fire
opened ecu and checked connections for the 8th time,everything is ok in there
it sounds like all 4 cylinders are firing at the same time instead of 2?
Old Aug 28, 2012 | 07:46 PM
tomoyb's Avatar
tomoyb
could the two black wires that go to ecu cause this if wrong way round?
im 99% sure i belled the one out to amp plug correct but now beggining to doubt myself as cant think of anything else
Old Aug 28, 2012 | 10:14 PM
whizzisat114
Pin 21 goes to ign one of the ign amps to pin 1
Pin 26 goes to other ign amp and goes to ign pin 6
Cheers david
Old Aug 29, 2012 | 07:07 AM
tomoyb's Avatar
tomoyb
Pmd
Anybody else got thoughts on this? Cheers
Old Aug 31, 2012 | 04:44 PM
tomoyb's Avatar
tomoyb
Have now belled out pin 21 and 26 and they were reversed.would this sound right to the engine firing but sounding like all 4 were firing all the time? Ive now changed them over and it just cranks over now and doesnt start
Any ideas?could this of damaged ecu.driver amps etc?
Old Sep 1, 2012 | 08:01 AM
tomoyb's Avatar
tomoyb
Anyone?
Old Sep 1, 2012 | 11:49 AM
polly_x's Avatar
polly_x
Have you tried turning it over with all four plugs out and connected to the leads? What order do they fire? Should be visible firing in pairs 1 and 4, 2 and 3.
IMPORTANT: Make sure you unplug the injectors when you do this.
Old Sep 1, 2012 | 01:03 PM
tomoyb's Avatar
tomoyb
Im not getting a spark now.ive changed ecu and still nothing
Old Sep 1, 2012 | 06:28 PM
boost mad's Avatar
boost mad
Did you buy everything new for the conversion ?
Old Sep 1, 2012 | 08:28 PM
tomoyb's Avatar
tomoyb
All working now
Old Sep 1, 2012 | 08:29 PM
tomoyb's Avatar
tomoyb
Thanks for everyones help
Old Sep 1, 2012 | 09:32 PM
onslack's Avatar
onslack
What was the issue?
Old Sep 1, 2012 | 10:19 PM
tomoyb's Avatar
tomoyb
21 wire reveresed with 26 at ecu.just pissed off i took advice elsewhere on it as i had it right first time but changed them.christ ive soldered driver into another ecu etc for it to obly be that
bigluke200
14
Sep 2, 2015 10:35 PM
rsturbo27
Sep 1, 2015 09:54 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ekjim
Aug 17, 2015 08:57 PM
muz
Aug 16, 2015 12:57 PM
