Cost of a zetec turbo?
Old Jan 24, 2012 | 04:09 PM
bobster1982's Avatar
bobster1982
Default Cost of a zetec turbo?
I've been looking at doing this for a while and am busy getting hold of parts. I have a 2.0 blacktop that I am looking at forging.
I will be using megasquirt management and a T3.
Now I know prices vary depending on if you get a few bargins and do the work yourself etc but how much would the average forged build cost?
Can you do things a bit cheaper with just pistons and OEM Rods with ARP bolts? if so what sort of power can you get?
Last question..
Is there any tips tricks and advice you can give me to get a nice reliable engine? Parts you have used that are very good or little niggles on the build you sorted?
Thanks
Rob
Old Jan 24, 2012 | 06:23 PM
nevsrevs's Avatar
nevsrevs
first of all what power to you want?, 2nd if your going forged, then a bogo t3 is a little on the low power side for a forged engine, we can go from there
Old Jan 24, 2012 | 06:32 PM
bobster1982
Looking for a fun figure... 250 to the 300 bhp mark. Going to be mated to an MTX75 box so that may be my sticking point.
Old Jan 24, 2012 | 06:37 PM
TomPengelly's Avatar
TomPengelly
Kapow!!
I did mine on a tight budget on my first build. Was just a standard 2 litre silvertop with 1mm skimmed pistons and ARP rod bolts, stage 3 T3 on cvh manifold with adaptor plate, rover turbo inlet manifold with adaptor plate, omex ecu, bigger front mount and an oil cooler pretty much. Lasted 3 years at that. Was set up at 255bhp at 14psi, but i turned it down to 11psi. That was with a deisel box with an RST LSD. Had my fun with it, killed it, now doing properly thanks to the boys on here
Old Jan 24, 2012 | 07:09 PM
nevsrevs's Avatar
nevsrevs
really if you looking for those power figures then i would try and do a budget build with a decomp plate ect, either that or go for it and forge it and a good turbo 350 plus bhp?
Old Jan 24, 2012 | 07:21 PM
bobster1982
Are decomp builds reliable though? And what power can you stick through a MTX box?
I've been offered this. It's a T3.75 hybrid
Old Jan 24, 2012 | 07:27 PM
nevsrevs's Avatar
nevsrevs
mtx75 are shit hot mate, best fwd ford box for the zt really, looks like a obx manifold, they are good, but what make is that turbo, not a cheap ebay spec is it?
Old Jan 24, 2012 | 07:32 PM
bobster1982
All i can tell you is its an American import. I can find out though
Old Jan 24, 2012 | 07:34 PM
nevsrevs's Avatar
nevsrevs
just be carefull with the turbo, but if its peanuts, obx are from the usa,
Old Jan 24, 2012 | 07:38 PM
bobster1982
Okay thanks for that. So say I have 2 grand and I can have a garage that can fit it.. what would you do? Will that get me a forged lump or am I dreaming?
Old Jan 24, 2012 | 07:44 PM
nevsrevs's Avatar
nevsrevs
800 for rods and pistons, 200 for block work, 30 for some 106 valve springs, 200-300 for gaskets and bearings, so yea could be done, but if i done all that, i would not be strapping a nasty turbo to it,
Old Jan 24, 2012 | 07:48 PM
bobster1982
What turbo would you go for?
Old Jan 24, 2012 | 07:52 PM
luke19790_3's Avatar
luke19790_3
what car is going in?
Old Jan 24, 2012 | 07:56 PM
crazycage's Avatar
crazycage
one of the td05's
Old Jan 24, 2012 | 08:13 PM
nevsrevs's Avatar
nevsrevs
all depends wat manifold and power you want? as above tdo5 or the ihi vf range, very cheap and can produce good power. too much choice.
Old Jan 24, 2012 | 09:53 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i did my build last year, Ł1200 on bottom end for a 2046cc forged rods, steel rods, arp mains and gaskets.
area six head, t04b ball bearing turbo, modded sx200 manifold, alloy HO inlet.
i had a lot of welding to do and machining to get parts to fit as to avoid spending where i didn't need to.
i reckon on about Ł3500 on the engine side (already had management and injectors)
around Ł1600 on mtx75 conversion, custom shafts, 6 paddle clutch and frs box etc.
all in a mk2 fiesta, loads of one off parts/mods done by me to keep it in budget and a compact setup where possible.
Old Jan 24, 2012 | 11:11 PM
bobster1982
My cougar
TD04 seems a good choice. are there off the shelf manifolds to fit?
I'm aiming for 250-300 bhp as said before so I'd like to build the engine to take more but have it turned down to maintain reliability.
So far I have bought..
Spare engine
Rover turbo upper and lower inlet manifold
Rover 440cc Injectors with the rail
Paddle clutch.
Arp bottom end bolts
Was looking at just forged pistons to save some cash?
Old Jan 25, 2012 | 02:43 PM
bobster1982
Is this the sort of thing to hunt for??
http://www.ebay.co.uk/itm/subaru-imp...item27c29cd09d
Old Jan 25, 2012 | 07:04 PM
nevsrevs's Avatar
nevsrevs
yea mate if he has paper work to prove its genuine? there was a manifold on the bay with the rite flange, under zetec turbo, i know for a genuine ihi vf28, but needs a new comp wheel,
Old Jan 25, 2012 | 08:17 PM
Darylc.'s Avatar
Darylc.
49cc superbike!
I was thinking to myself earlier about how you dont see too many modified cougars
Old Jan 25, 2012 | 08:49 PM
LukeDaisley's Avatar
LukeDaisley
My mondeo drive train will one day make its way into a cougar.
Old Jan 25, 2012 | 09:58 PM
bobster1982
Fourby mondeo? Easily done on the cougar. Both the zetec and v6 has been done. The v6 does require some chopping on the block though.
Old Jan 25, 2012 | 11:36 PM
JohnnyRS's Avatar
JohnnyRS
Is there anyone actually running a proper budget zetec turbo?
I.e.
Decomp plate
RS Manifolds + adaptor plates
T3
ARP rod bolts etc..
Most of the threads on here about them lead to nothing or have been ruined by MO
Old Jan 26, 2012 | 05:30 PM
nevsrevs's Avatar
nevsrevs
yea there have been a few pikey builds, would love to do one just for giggles
Old Jan 26, 2012 | 05:56 PM
forevaford's Avatar
forevaford
My cougar
Spare engine
Paddle clutch.
hi mate, iv got a 290 bhp zetec turbo build, forged pistons, standard rods, 8:0 comp ratio, ported head and manifolds, standard cams. stage 3 t3 turbo 25 psi boost peak holds about 22. mega squirt ecu. and its done 22k miles with a hard life, (turbos smoking now though) but i think the rods a near there limmet here
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
