Limp reving
Old Oct 17, 2011 | 07:28 PM
harrybo's Avatar
harrybo
Default Limp reving
Hi guys and girls my name is Harry and am just new to the place.
Unfortunately my first post is not a good one
I just purchased a 52 plate focus st170 very happy until I was driving along about 30 steady revs at about 2k then it was starting to what I think missfire, then on the bypass it would not pick up speed or revs, done a wee bit looking on hear already and I see alot of problems with the fuel pump, I am not the best when it comes to cars and was wondering if anyone can shed some light on the matter,
Much appreciated
Old Oct 18, 2011 | 01:45 PM
harrybo's Avatar
harrybo
Well a wee up date my engine management light came on and the fault code said it was the fuel rail pressure sensor so just going to order one up and see what happens
Old Oct 18, 2011 | 02:09 PM
James @ M Developments.'s Avatar
What did the fault indicate? maybe it flagged a rail pressure sensor because the rail pressure was low, the sensor may be working just fine.
You need to check the fuel pressure and reference it to the ECU data from the rail sensor.
Old Oct 18, 2011 | 02:17 PM
harrybo's Avatar
harrybo
Well my friend plugged in his tester and the only fault that came up was just the fuel rail pressure sensor, lucky my friend works for ford as a parts manager so I asked him to order me a new sensor plus coil pack as I know these go very often and if there is still a fault I will order a new fuel pump really hope I don't have to tho as I know they can be costly,
Old Oct 18, 2011 | 02:32 PM
That is a costly way of finding the fault though as you may end up replacing numerous sensors that are not faulty at all,
Some in depth diagnoses would be a better option to actually find the fault.
Old Oct 18, 2011 | 03:02 PM
harrybo's Avatar
harrybo
Ye that's true I will run some fuel pressure tests, do u recommend any test to try? I know the fuel pump and modulator are common on failing
Old Oct 18, 2011 | 03:14 PM
just measure the line pressure and see what it is, then see what the rail pressure sensor says you have.
Old Oct 18, 2011 | 03:18 PM
harrybo's Avatar
harrybo
Cool thanks will get on it fingers crossed it's something simple
Old Oct 18, 2011 | 03:31 PM
R4N SS's Avatar
R4N SS
so you're just goin to replace the fuel pump without even making sure it is that which is causing the problem
Old Oct 26, 2011 | 04:28 PM
harrybo's Avatar
harrybo
Quick up date just gave the car a service and the spark plugs were goosed but the mechanic has said there looks like water beside the spark plugs, does anyone know if this is a common fault be said it's a slight water leak
fuzzy
Sep 4, 2015 10:11 PM
Timmy74
Ford Mondeo Including ST
Aug 28, 2015 01:21 PM
Neatrags
Aug 16, 2015 07:57 PM
nick8saff
Aug 16, 2015 05:35 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
