rst boost problem
Old Jul 4, 2011 | 02:00 PM
Sjieter's Avatar
Sjieter
Default rst boost problem
it's running standard boost 0.55bar (8psi) but i changed my broken standard actuator to a -31 actuator. thing is in 3th 4th and 5th it overboosts. running 0.6 bar sometimes even goes to 0.7 bar in 5th gear. this guy said its because the amal valve can't work with the -31 if it aint chipped. on my standard actuator it didnt have this problem it ran lower boost 0.5 bar but peaked at 0.52 bar when it wasn't broken yet.
Anyone know what is really causing this?
Thanks
Old Jul 4, 2011 | 03:18 PM
anvini's Avatar
anvini
Thanks
Hi mate!
Ecu cuts out when boost goes to 0.7bar??
You must to adjust the actuator rod to get the boost pressure needed.
You need to extend the length of actuator rod to decrease boost pressure , so the actuator will open wastegate early and boost pressure will drop....
A fine tuning on the rod.
Hope this helps.
Old Jul 4, 2011 | 04:02 PM
Karlos G's Avatar
Karlos G
Balls Deep!
As above mate, lenghten the rod a turn and see how you get on, then another if needed till you get it right.
Old Jul 4, 2011 | 04:04 PM
Sjieter's Avatar
Sjieter
well there's the problem, i have the rod adjusted that it just goes over the arm of the wastegate, if i make it any longer my wastegate will be open all the time. Ecu is adjusted i think when i first had the actuator on before adjustment it went over 1 bar without cut out just kept going. in 1st and 2nd i constantly have 0.55 bar as it's supposed to be but in 3th 4th and 5th the gears are longer and the higher the rpm the higher the boost. highest it goes is like 0.72 bar. And from what ive heard the amal valve gives 2 fast clicks when unchipped and 2 clicks with delay if chipped. mine gives 2 fast clickes
Old Jul 4, 2011 | 04:10 PM
Sjieter's Avatar
Sjieter
oh and in 3th 4th and 5th it have 0.55 bar but after a while it goes up , it doesn't instantly go to the 0.7 bar. goes up with rpm
Old Jul 4, 2011 | 05:22 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Sorry just re-read your first post, a -31 actuator will hold a minimum of 10psi (compressor housing) so you will either need to chip it or maybe lose the amal and plumb the actuator direct to the comrpessor housing.
Old Jul 4, 2011 | 06:36 PM
Sjieter's Avatar
Sjieter
and if i bypass the amal valve , as a temporary solution. will it do any damage? i bought the -31 because it said at the info minimum of 0.55 bar to 2 bar. i was thinking about getting my boost upped to 0.7 - 0.8 bar. and buy a fmic with it. 0.7 - 0.8 bar is still safe right?
Old Jul 4, 2011 | 06:53 PM
cabrst's Avatar
cabrst
had the same with my S1
You have to make the rod longer, that cure mine, but are having a chiped ECU on the way
Old Jul 4, 2011 | 07:17 PM
anvini's Avatar
anvini
Maybe with a bleed valve???.....
http://www.ebay.co.uk/itm/Brass-lock...item415b55f663
Old Jul 4, 2011 | 07:28 PM
Sjieter's Avatar
Sjieter
yeah i think ill try a bleedvalve. just disconnected the amal valve gave me 0.3 bar.. didnt have any punch in it really. ill just connect everything back and just dont go full throttle.. i always give like 90 percent throttle which still gives me my 0.55 bar
Thanks for the help guys
Old Jul 6, 2011 | 10:25 AM
Rogeyboy's Avatar
Rogeyboy
As has been said the -31 will run a minimum of around 9/10psi, so adjusting the rod will never give you any less boost than that. I'd recommend a chip and a re-jet of the amal valve and you will be away!
And Yes 0.8bar is fine with the standard cooler, so even more fine with the Front Mount...
Old Jul 6, 2011 | 04:48 PM
Sjieter's Avatar
Sjieter
ok thanks, and what power would i be looking at with :
-airtec fmic
-kent cvh 31 ( already in the car when i bought it )
-full mongoose
-standard turbo with 0.8 bar?
i hope for a 150-160?
Old Jul 6, 2011 | 05:18 PM
Karlos G's Avatar
Karlos G
Balls Deep!
You will be around 150bhp.
JK12
33
Apr 26, 2021 12:09 PM
Billy_RS
Sep 13, 2015 04:17 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
