st170 reverse light problem
Old Jun 6, 2011 | 09:29 PM
ray170's Avatar
ray170
Default st170 reverse light problem
hi have a reverse light problem does not come on put tester in lights up put bulb back in does not work tried different bulbs same prob tester still lights up thanks ray
Old Jun 9, 2011 | 03:36 PM
Bad connection ie a high resistance somewhere, the reason why it lights the tester but not the r/l is due to the r/l needing more current, you will likely find the r/l does work but only a faint flicker, usual suspect is bad earth.
Old Jun 13, 2011 | 07:17 PM
mcst's Avatar
mcst
Does the rear wiper come on when you put it in reverse with the wipers on?
We've got the same problem with ours and suspect it is the switch as the bulb is fine etc and the wiper doesn't come on when engaging reverse.
Old May 19, 2017 | 01:33 PM
DJ_AL's Avatar
DJ_AL
Sorry folks i'm opening up this old chestnut!
My ST170 reverse lights aren't coming on (bulbs/fuses changed) but my wiper does, which I assume means my reverse switch is fine.
Does this means i'm having the resistance issue (bad connection) as noted above? Any tips appreciated.
Old May 19, 2017 | 05:04 PM
DJ_AL's Avatar
DJ_AL
Sorted it! I noticed my fog wasnt working either so checked it and it was full of water!
Once I had them both unplugged and off the car I realised how badly corroded the connections were.
After drying out and cleaning up they work a charm.
Old May 19, 2017 | 06:13 PM
STeve's Avatar
Super Moderator
usual on these mate as seals are not water tight
Old May 19, 2017 | 06:53 PM
DJ_AL's Avatar
DJ_AL
It was half full! Haha. It must been that way since I've had her which worries me, since the mot 3 months back I've had to change two badly damaged tyres, a perished sump, cambelt at death's door, fix a thermostat leak and they clearly didn't check the lights!
On a different note I'll likely pester you for a bonnet in a few months (when my bank account recovers!) As my paint is not so clever on mine.
Old May 20, 2017 | 09:29 AM
STeve's Avatar
Super Moderator
Breaking a NOS powered magnum grey track car at moment which is fun
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
gulliver
Ford KA
Aug 31, 2015 01:42 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
jaysoc1
Aug 20, 2015 08:18 PM
