What polish to use for machine polisher
Old Feb 2, 2011 | 06:22 PM
Default What polish to use for machine polisher
Hi people.
What polish do you use for a machine polisher when your buffing cars.Ive just been getting a machine polisher and i wanna try and get the swirl marks out of my dads car.
Old Feb 2, 2011 | 06:31 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
I use g3 witha hard mophead, then g10 and another compund called black top, with a soft mop head, then a lick of polish finally, it will get the swirls out and look like mirror mate
Old Feb 2, 2011 | 06:32 PM
Rsmat's Avatar
Rsmat
depends on what colour... make of car...and age of car.
Old Feb 2, 2011 | 06:53 PM
wrcjim's Avatar
wrcjim
For really top job use 3m trizak disc p3000 grade on a D.A with soapy water. Use 3m fast cut compound (green top) for polishing.For dark colours use blue top. Use these with a hard compound mop. Finish off with a soft finishing mop useing 3m finnesse it or machine glaze.
G3 is ok if the above can't be sourced
Regards
Jim
Old Feb 2, 2011 | 07:00 PM
bristol_fez's Avatar
bristol_fez
I like using the menzerna range of polishes, but it all depends on the car you are planing on doing.
Old Feb 2, 2011 | 08:49 PM
Moonstone Mo's Avatar
Moonstone Mo
+1 menz range is great
Old Feb 2, 2011 | 09:25 PM
jason_nike's Avatar
jason_nike
Must note all tips, want to get a polisher for my cars this summer
Old Feb 2, 2011 | 10:13 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Dont forget some polishes like the 3m range are best suited to a rotary not a da
Old Feb 2, 2011 | 10:37 PM
Frenchy0204's Avatar
Frenchy0204
Get to tha choppa!
I'm surprised none of you guys have told him to clay bar the car first, otherwise he would be rubbing all that grit into the paint, making more swirl marks...
Old Feb 2, 2011 | 10:52 PM
andy130's Avatar
andy130
try using 3m mate you'll never use g3 /g6 ever again miles better
Old Feb 3, 2011 | 07:34 AM
colarado red's Avatar
colarado red
Have a look on the Clean Your Car website.I use the Sonus pads and polish work well on Ford paint.You can also use Autoglym SRP via a da/rotary polisher but it's filler heavy.
Old Feb 3, 2011 | 08:09 AM
rog's Avatar
rog
Same here!
As for the claying comment, you're right, but why stop there, we can talk about using the 2BM, snowfoam, etc...
Old Feb 3, 2011 | 10:47 AM
Moonstone Mo
Glenn has already familiar to claying the car..lol
im sure he will prep the car before hand.
Old Feb 3, 2011 | 02:38 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
what would you's use on a tornado red mk5 gti with swirl marks? (pads/polishes? & speed?)
Old Feb 3, 2011 | 02:44 PM
Fiddy's Avatar
Fiddy
Use the stuff i gave you when i gave you the buffer
Old Feb 3, 2011 | 04:01 PM
JamboRS's Avatar
JamboRS
focus rs 1672
dave i use the menzerna and 3m polishes and hexlogic pads
vag paints usually quite hard and take a while on a DA.
start with the least abrasive and step up pad,then polish then pad then polish until you get the correction you want.then use a finishing polish to refine.speed wise you just need to see what works
Originally Posted by Glenn.
Hi people.
glenn try the menzerna sampler pack.has everything in it you need to get swirls out and wont break the bank to start out,then just add to it at a later date
http://www.cleanyourcar.co.uk/polish.../prod_220.html
Old Feb 4, 2011 | 10:35 AM
vroooom ptssssh
It Wasnt Me!
Cheers Jamie, i'm new to the machine polishing so just looking for pointers before I wreck it. Using all that with the machine rather than pad/hand polish/pad?
Old Feb 4, 2011 | 10:42 AM
chaffe's Avatar
chaffe
Turbocharging Technician
bit of advice, dont knob the paint by burning through lol
Old Feb 4, 2011 | 06:47 PM
vroooom ptssssh
It Wasnt Me!
I've read not to stay on the one spot for too long, keep it moving...
going to try on his front wings first as they are getting replaced by VW as they have started to rust so they should give us a good indication of how the rest should be done
Old Feb 5, 2011 | 07:46 PM
chaffe's Avatar
chaffe
its mostly the corners you will knob first, lol
Old Feb 5, 2011 | 07:49 PM
Rich1880's Avatar
Rich1880
I use Menz polish but always finish with 'Carkandy Juiced Polish' its amazing stuff and not stupidly priced!
Old Feb 6, 2011 | 10:08 AM
opposite lock's Avatar
opposite lock
Hi Glenn did you have any joy?
Old Feb 12, 2011 | 01:48 AM
benn_moon's Avatar
benn_moon
i would recommend a rotary polisher for safe use! i still managed to remove paint on the corners and edges using a rotary polisher for the first time! jap paint work can be very soft and easy to remove!! go easy, start with less abrasive compound as you can always move up! and somethimes less abrasive gets rid of the swirls and holograms! make sure you polish out the compounds as the particles break down and reduce in size the longer its used getting less abrasive!
Old Feb 14, 2011 | 07:15 PM
Well my mam and dad have decided to get a new car so i wont have to do the focus now lol.
Ive used clay bars before and there quality.
Old Feb 14, 2011 | 07:17 PM
EEEEEhhhhhh well fook me sideways i never thought of that.You comic i hadnt forgot about it i was just wanting to know what over people were using.
Old Feb 14, 2011 | 07:25 PM
Fiddy's Avatar
Fiddy
take it to work, try it on one of the post vans, then we can do my car if its any good
Old Feb 15, 2011 | 09:25 AM
st170dan's Avatar
st170dan
you ideally want to try a range of polishes. start of with a finnishing polish on a finnishing pad and assess whether this is giving you the level of correction you require. if not consider moving upto a polishing pad and/or polish and assess again. with polishing there is no correct formula - different paints require different combos to correct, and deep defects may not be able to remove completely. check out detailingworld.co.uk for professional polishing advice. they have a really good guide on polishing. hth
Old Feb 15, 2011 | 12:55 PM
Sp3no's Avatar
Sp3no
Throw the G3 in the bin, its what bodyshops use to remove lots of paint fast to improve a bad paintjob, it will actually leave a swirled finish its VERY aggressive
Old Feb 16, 2011 | 06:44 PM
Brian's Avatar
Brian
What i bought to do our cars with had a little go on the bonnet on our Mondeo and it come up like new just need a nice day so i ca ndo the whole car
Brian
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
caprixpack
Sep 25, 2015 07:53 PM
timsrs
22
Sep 24, 2015 08:14 PM
