Fiesta RS1800 Fuel Problem
Old Dec 1, 2010 | 03:44 PM
Brian's Avatar
Brian
Default Fiesta RS1800 Fuel Problem
We are having trouble with my dad’s Fiesta RS1800, it seems to be over fuelling the car will start but seems to be choking itself and cuts out, when you turn the ignition on you hear the fuel pump running continously normally you just here it prime its self and then it stops, the last few days when your cruising along and go to put your foot down a little bit you can hear a relay under the dash clicking on and off
Anyone got any ideas
Cheer's Brian
Old Dec 1, 2010 | 03:49 PM
sjoyce666's Avatar
sjoyce666
I'd replace the relay first of all and if thats not it then look into lambda and catalytic converter. I had issues with fuelling when I had my 2.0 Si. Changed both the lambda, Ł20 eBay job, and the catalytic converter and the fuelling was spot on
I didnt have any issues with relays clicking or the fuel pump running so would start by replacing the relay
Scott
Old Dec 4, 2010 | 01:54 PM
Brian's Avatar
Brian
Have just tried another relay but its still the same
Any other idea's
Cheer's Brian
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
taylora1409
Aug 12, 2015 12:06 PM
Bosch
Aug 4, 2015 05:14 PM
