fiesta loom conversion help
Old Nov 14, 2010 | 10:35 AM
shepherd-racing's Avatar
shepherd-racing
Arrow fiesta loom conversion help
hey , ive got a mk3 fiesta witch origenaly was a 1.3 now its running a 1.6 mfi engine on carburetor witch is an easy conversion , now i want to run injection without any major changes ie full engine change and i'd like to keep it running on distributor , i know i need an mfi-efi adaptor plate to run xr2i or frst inlet manifold but is it posible to just edit out the coil pack wires on the loom?and just have it running mostly the fuel management , idealy this is to get the car ready for when money suits a 1.6 turbo conversion ,
are the xr2i and frst looms the same ? i know the 2i doesn't have boost control? but what else is different ? some rs turbo's run distributor thats why i'd like to keep mine so the change over is "simple" ,do the ecu's cross over? if the same type ofac or ofab if thats right ?
bear with me im a novice at this and probrably cant spell any help to get me to my goals will be much apreciated , sorry if repeat post
Old Nov 16, 2010 | 08:39 AM
shepherd-racing
does any body know? surely theres enough technical boffins on here to go yes or no , some one ask someone who might know cheers
Old Nov 16, 2010 | 08:50 AM
fezzielove's Avatar
fezzielove
hi buddy have splice'd efi looms into mk3 before quite easy these a ecu pement live on red and a ignition live black these can be found on the efi engine loom to interior loom connector 8 wire connector on the engine bulkhead there is a green wire for revo will have to doublle check what the other wires are for, why would you want to run a dizzy seems pointless going half the way as the ecu alters the fueling and sparc in sync and would imagine would get confused also for the work thats involved ie changing flywheel for one with cps teeth for crank sensor you might aswell put the coil pack on
Old Nov 16, 2010 | 08:54 AM
shepherd-racing
yeah i think im going coil pack to be honest , ive got an old escort fly wheel the small clutch pattern on , im told its lighter , so realy its looking like more hassle then its worth at the mo
Old Nov 16, 2010 | 08:56 AM
fezzielove's Avatar
fezzielove
yeh i would go all the way buddy dont know about the small flywheel thought they were all the same if you struggle to find a efi i know some one who has 5 or so in blackpoool
Old Nov 16, 2010 | 08:58 AM
chaffe's Avatar
chaffe
Turbocharging Technician
To be honest, and please dont take offence, it sounds like you need to know more about what your talking about. Prehaps you are struggling to put it into words? From what i understand you have a 1600 cvh, with a distributor and carb? and you want to make it k-jet injection? and a future turbo conversion requires this?
Old Nov 16, 2010 | 09:19 AM
shepherd-racing
yeah pretty much , but i think its going to be easyer now to just put turbo engine and loom in at once , didn't want to waste the engine ive got as its over bore'd lightened ballenced internals etc cheers for your help
Old Nov 16, 2010 | 09:25 AM
chaffe's Avatar
chaffe
yeah best to use all the frst bits, the twin coils are bulletproof, better than any distributor set up. you will need a CPS and the edis4 module and loom for the ecu to run anyway, regardless of wether you use the coils or not.
Old Nov 16, 2010 | 06:57 PM
shepherd-racing
[quote=chaffe;5187681]To be honest, and please dont take offence, it sounds like you need to know more about what your talking about. Prehaps you are struggling to put it into words? quote]
yeah my english is poor , i dont know what i need thats why im asking so now we know were i need to go what bits do i need to change over? fuel pump ?( 1.3 injection pump is there) should i just buy an inline pump and use in-tank as extra?
are all frst running the same loom - ecu etc? so if i can only sauce parts from breaker etc i can mix and match? donor cars an obvious choice but buying one defeats the object of building one
what parts do i need? ive got a deisel box already , presume i need loom - ecu - clocks? - mafs but what else? they dont use lambda sensor do they?
Old Nov 17, 2010 | 12:36 AM
mrjenrst's Avatar
mrjenrst
tbh mate you'd best read up on them first otherwise it may cost you a bit of coin. Why have you got a diesel box?
Old Nov 17, 2010 | 08:16 AM
shepherd-racing
im told theyr stronger im doing my reading up and asking questions
Old Nov 17, 2010 | 08:19 AM
chaffe's Avatar
chaffe
whats stronger? stilton or kippers
Old Nov 17, 2010 | 10:18 AM
shepherd-racing
the deisel box is , isn't that why alot of zvh'ers use it? taller ratio top end, good differential ,
just want to know what bits i need for conversion now please
Old Nov 17, 2010 | 10:42 AM
chaffe's Avatar
chaffe
Negetive, diesel boxes are internally the same and therefore are NOT stronger. They do have taller ratios though. An MTX75 (as in mondeo, mk5/6 RS2000, or mk5 TD/XR3i 130) gearbox is, however much stronger. But fitting this box requires many custom parts and a bit of engineering
Old Nov 17, 2010 | 01:01 PM
shepherd-racing
cool , not realy fussed just want turbo now
Old Nov 17, 2010 | 01:06 PM
chaffe's Avatar
chaffe
Thats the spirit
Old Nov 17, 2010 | 01:08 PM
shepherd-racing
so then chaffe what do i need? other then the obvious? loom-engine- intercooler?
what else ? radiator?
Old Nov 17, 2010 | 03:59 PM
mrjenrst's Avatar
mrjenrst
An frst donor car otherwise you'll just be going round the house's to get what that can offer for a lot less.
Old Nov 17, 2010 | 06:56 PM
chaffe's Avatar
chaffe
yeah, a rotten frst would be astart
Old Nov 17, 2010 | 09:25 PM
shepherd-racing
decided to go a different route , thinking of just getting a cam and bike carbs and look for another car thanks for the help everyone
Old Nov 18, 2010 | 06:05 AM
chaffe's Avatar
chaffe
Oh, not soo good best of luck all the same
155lee
Oct 24, 2015 11:11 AM
IainRS1700T
Sep 25, 2015 06:44 AM
liamT74
Sep 23, 2015 10:24 PM
Maxwell
Fiesta ST
Sep 13, 2015 05:31 PM
Ben26
Sep 3, 2015 07:55 PM
