Escort tarmac suspension from Reiger Racing
Old Oct 20, 2010 | 10:27 PM
axelriet's Avatar
axelriet
Default Escort tarmac suspension from Reiger Racing
Just got it today. The build quality is outstanding. 62mm struts with 50mm inserts, springs OD is 90mm and the dampers are 3-way adjustable. The front dampers are called 5062 and the rear are 4616.
The turret extensions were sourced from Dewitts. I specified the top-mount and sent drawings then Reiger built a custom off-center mount to meet my specs and the turret extensions. We'll mount the front dampers in the car with the offset towards the rear, to increase castor a bit and leave the camber alone.
I won't discuss the settings are they are completely dependent on the intended use of the car, but Reiger can essentially make exactly what you want. You start from the corner weights and intended use (smooth or rough tarmac, gravel, race car, recce car...) and they come up with spring rates and base damper settings to suit your car and its use. The cost was approx 4000 Euro delivered.
ETA: on a historical note, this was the first ever Reiger set made for the Escort Cosworth. I’ve designed the top mounts myself in SolidWorks to match the WRC turrets and their uneven drill pattern, and sent the CAD drawings to Reiger. If you look closely the top-mounts are 24mm off-center rearwards, to add a bit of caster. In the world rally car the top mount offset is outward to accommodate the wider track but since the road car has the standard-length TCA and hubs, I choose to use the leeway to increase caster instead of track.
Old Oct 20, 2010 | 10:29 PM
JonnyBravo's Avatar
JonnyBravo
Is this a advert or something.
Either way, that is suspension porn
Old Oct 20, 2010 | 10:35 PM
axelriet's Avatar
axelriet
No, I'm just a customer.
Old Oct 21, 2010 | 09:08 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Nice suspenion. Whats it like in comparison to the Ohlins.
Old Dec 7, 2019 | 08:10 PM
axelriet's Avatar
axelriet
Haha another thread back from the dead - I have no idea about the Ohlins except that (from a picture a saw) the Ohlins apparently follow an old school design with short travel and stiff springs by the look of them. Reiger promotes long travel, soft springs and lots of hydraulics, which is the modern take on suspensions. They have since won a few WRC titles notably with Ford and all WRC2 titles with Skoda and Ford so their approach is obviously right.
They also made another bespoke set for me with 4x 5062 which is now on my Focus RS.
Old Dec 4, 2021 | 07:35 AM
SAGO's Avatar
SAGO
It’s been a long time but how is your experience with the suspension? I am thinking of having REIGER on mine similar as yours. It’s for my road car use. I got tired with the BILSTEIN I have now….
dal3door
Aug 13, 2015 06:55 AM
scoooby slayer
Jan 4, 2015 11:40 AM
TrevCos
Apr 23, 2011 02:26 PM
volcomstone411
Jul 7, 2009 10:39 PM
Red16
58
Jul 31, 2007 02:07 PM
