Abs problem help!
Old Apr 23, 2019 | 12:07 PM
Mipasasa's Avatar
Mipasasa
Default Abs problem help!
So I have an abs problem which has baffled me for a while now. The original problem was when pressing the pedal both the abs and handbrake light would illuminate and switch the abs pump on. The accumulator would pressurise but only last one pump of the brake. OK fast forward, I have replaced the accumulator. Red light now stays off. The pump still runs everytime I fully depress the pedal and it switches the Amber abs light on. The system pressurises much quicker now. I have a 3pin diagnostic reader and have checked both 3 pin connectors near the battery and they both have no codes. There is a small 5pin connector near the abs module but I don't know what reader is needed. Any help would be greatly appreciated! CheeRS
On another note. I've checked all the abs sensors and rings. The car is very low millage and has been kept indoors so there is no dirt or anything stuck on them.
Old May 4, 2019 | 08:08 PM
Cossy Mike's Avatar
Cossy Mike
Mine was doing the same thing, I swapped to another used accumulator and its a little better but Ive a feeling ive just put another bad accumulator on
Old Dec 11, 2021 | 02:12 AM
lime's Avatar
lime
I am experiencing something similar to this, could it be the pressure switch ?
Old Dec 11, 2021 | 08:06 AM
Cossy Mike's Avatar
Cossy Mike
mine turned out to be the green relay that controls the low pressure, it was stuck
reisskahn
Mar 31, 2010 10:44 PM
rostill2007
Jun 12, 2008 07:25 PM
155lee
Mar 25, 2007 05:39 PM
Beach
Jul 10, 2006 03:49 PM
MARKYMARKONE
Jan 20, 2005 07:25 AM
