ABS Problems
ABS Problems
When i pull up to a junction the ABS seems to make a funny sound almost like its coming from the pump...
Then the pedal drops from beneath your foot but the brakes still work just feels weird, then the pedal pumps back up and you can hear more weird noises from the pump untill you stop
It clears and then after a driving again does it the next time you come to a stand still.
Any help will be great...
Kindest regards
Kindest regards
Take all 4 sensors out and clean the metal face where the bolt sits refit and it should be OK.
The sensors are fragile so be carful on removal.
I have had to do this a few times over the last 15yrs of ownership.
There is another cause but that needs an auto eletrican and leads to a bill LOL
Hi,
If this only happens at low speed and no ABS light coming on it could be you have a damaged abs hub ring!
You will have to check each one very carefully for a small crack or tooth missing.
CheeRS, Mike
CheeRS, Mike
Testing the future
it's a very common problem that is a speed mismatch from front to rear sensors. almost guaranteed to be cured by what ozcos has said, although it's usually only the fronts that give problems
Cheers,
