S2 Upgrades, whats the best beginner mods?
So I'm going to rebuild the car from top to bottom. So far its got
2.5" single box system
Polybushes all round
Uprated Shocks & springs
Uprated Waste Gate (would this mean my Turbo is uprated?)
The brakes and the engine are standard so I'm wondering whats the best route to go with upgrading them on a modest budget.
Rep for any help given.
BRAKES.
bailey breather just to eliminate future air leaks.
chpped ecu -31 actuator can all be done on a budget i got an ecu and actuator from ebay for Ł60!
front mount intercooler if youve got a few hundred quid to throw at it
As for the Chip, which ECU holds it? The Galvanised one or the black plastic one?
Turbocharging Technician
before any chip i would fit a decent intercooler as the standard one is crap and if your taking it to shows , most shows tend to be in the summer so one is needed...
chip/intercooler and -31 should see 180bhp with the right tuner but to be honest leave it with the standard cam as they drive nice at that spec and later to hit 200bhp if you fancy just add a stage 2 t3 turbo.
job done.... but remember at 180bhp t a genuine ford clutch is ok but when you get close to 200bhp an uprated one is needed and starts to take away the nice drive of the car.
just saying if hes wondering what sort of power he has now might as well get it set up and put on the rollers with a reputable tuner they willalso tell him if he nees a cam belt if its needed as they most likely will give it a check efore reving the bollocks out of it after its set up least then he knows the power andand can get advice where to go next depending on how he wants it to drive and the sort of power he wants sorry bout the crap english lol
Mongoose exhaust 2.5 inch bore, original airbox modified at the front for extra airflow with k&n panel filter, motorsport devolpments chip (i have one for sale if interested) or ahmed bayjoo, turbosystems chip, decent alloy intercooler airtec or radtech, grs etc then a set up personally i would leave it at that as you will have a nice 180-190bhp road car at around a bar of boost and if you want to more for that magical 200bhp just change the cam say to a newmans or upgrade to a stage 2 turbo, dont forget to upgrade your brakes and suspension, for suspension i would go no lower than 30mm and go with koni adjustables and brakes if you want bigger then go cossie disc conversion or if you want to stay standard size go for tarox or say ebc and some ferrodo dsp pads and braided hoses all round hope this helps m8
At the moment the car isnt road worthy, its solid but isnt running great, takes a long time to start, boosts at 4k and is dead as sand before that.
I'm completely out of my depth with this as I've been a Vauxhall for years and before when I had RSTs, I just drove them and no more. lol I dont even know what Boost is! lol
So, the engine spec list:
Service
Chip (if its not already)
Intercooler
then maybe a larger turbo?
Brakes:
As Cossies are hard to find here, anything else that could donate its stoppers?
Service
Intercooler
Brakes:
If you are going for a front mount get an msd 82 degree thermostat and uprated fan switch as alot of rst's suffer with very high temps as the coolers block airflow to the rads, brakes you can go for focus st, mondeo st, etc
Service
Intercooler
Brakes:
Service
Intercooler
Brakes:
lol yes mate when i got mine completed a full service including cambelt a couple of months later found i had developed a bad bit of piston slap and my crank was fooked due to it running lean at top end bit off the subject how much did your megasquirt efi cost as i will be gong efi ans i was looking into going for the gotech pro x later next year and wondered wht differences there are n price and perfrmance
Service
Intercooler
Brakes:
Service
Intercooler
Brakes:
once its all running right, has mot and you'r able to drive it on the road then and only then should you look at upgrades. no point upgrading an engine that doesnt fucking run right in the first place!
Cheers folks. The mechanics side of it doesn't worry me but the Turbo thing is new to me. The engine runs fine but takes a lifflt effort to start, something a service, filters and HT leads will more than likely cure it.
I've been pricing Cosworth front discs and pads, a whopping €200 and thats without Calipars. Looks like I'll be checking under the sofa for loose change!
