mountain bike brakes?
Im going to buy a bike to get a bit fitter but i have not been on one for about 10 years. Im going to be doing a bit of dirt and road riding. Since i last had a bike brakes have changed a bit from the old caliper type. I dont know which to go for either Disc brake setup or v-brakes?
Any body had and experience with these or can compare the 2?
Most bikes now have discs now.
Beware of the cable ones as imo a good set of V's are better.
Have a look at www.chainreactioncycles.co.uk for some bikes.
slightly out of topic here but years ago i purchased the xtr f+r caliper setup , had a metal rod and cable with extra length pads ..........fook me is all i can say. They were lethal and caught everyone who had a go out! Me being the 1st person to go straight over ass over tit , immense braking power , i,ve not been involved for years but had a quick go of others with new decent stuff and nothing touches them imo.
I,d definately go with the advice above ^^
mike
mike
In my personal experience, I managed to get shimano deore v brakes to work amazingly well. I used to use them years ago on my old DMR and preferred them to hope hydraulic discs and they were a fraction of the price.
^^^^not sure if theyre still making them but xt paralel pulls were the brakes of choice for me when i used to ride trials,amazing control!
from personal experience stay the hell away from halfrauds-total junk that wont last more than 6 months.
for the kind of money your looking at spending your better off sticking with v-brakes.
also stay away from rear suspension as it will only soak up your preload when on the road.
hth
hth
Compared to a good set of discs, rim brakes are shit.....even magura's. Touch of damp or mud and they just dont work, and if you get pads aggressive enough to cut through it they wear out in 5 minutes.
However at your price point and probable usage the v brakes will be better than the cable disc unless you fall lucky with some avid or shimano ones, which i doubt.
Cheap disc brake bikes suffer with poor kit too as the cash is spent on the disc brakes and hubs.
mike
mike
I've recently bought a decent bike, it uses Shimano Discs front and rear and I wasn't overly impressed, but do weight 330 tons, no pounds!!
Trying to get some cossie 4 pots on there!!
i have avid jucy 3 hydraulic discs which id recomend if you get the chance but in your price range id go for simple cable discs tbh, & thers nowt wrong with halfords bikes just dont let them put it together for you.
cheers nic
cheers nic
At that price range, go for V's. Only Hydraulics are better! Avid or Formula are by far the best, with hope coming basically last
they suffer from horrendous caliper flex, barely ever work, and have a tendancy to blow their pistons out. Everyone I know who's had hopes (alot I might add) have had problems with them having no power, or leaking, one of my mates even had his front brake blow a piston out at aston hill(no fun if you know how steep it is!) Hopes are 'all noise, no power' due to the noise most of them make! I even had a set of bottom end tektro hydro's that I used when I was skint that I prefered to hope, and they worked better!
they suffer from horrendous caliper flex, barely ever work, and have a tendancy to blow their pistons out. Everyone I know who's had hopes (alot I might add) have had problems with them having no power, or leaking, one of my mates even had his front brake blow a piston out at aston hill(no fun if you know how steep it is!) Hopes are 'all noise, no power' due to the noise most of them make! I even had a set of bottom end tektro hydro's that I used when I was skint that I prefered to hope, and they worked better!At that price range, go for V's. Only Hydraulics are better! Avid or Formula are by far the best, with hope coming basically last
they suffer from horrendous caliper flex, barely ever work, and have a tendancy to blow their pistons out. Everyone I know who's had hopes (alot I might add) have had problems with them having no power, or leaking, one of my mates even had his front brake blow a piston out at aston hill(no fun if you know how steep it is!) Hopes are 'all noise, no power' due to the noise most of them make! I even had a set of bottom end tektro hydro's that I used when I was skint that I prefered to hope, and they worked better!As reliable as an arga, if serviced and looked after as per the manufacturer spec
I use Mono Minis on my all day full susser and they're tiny single pots and are perfect, plently of power and feel and never let me down.
I wouldnt have used them when I was living in wales and hammering the big hills every other day.
Plus I can go to my local shop and get any spare part by the next day if I need one, say if i'm swapping bikes etc.
Not saying your wrong but in my experience they are pretty decent
I guess it depends on speccing the right brake for the usage
Have to agree with you there mate! But im using the older Hope stuff so wouldnt know what the new stuff is like!
What sort of riding will you be doing? How good are you on a bike? theres no point over spending if you carn't do what the bike is capable off.
Disks are better than rim brakes but at your budget your propabley looking at cable disks which are great if you wont to poddle about as are the v brakes tbh there is'nt alot in it at this price level
sridgett
Oct 1, 2015 07:30 PM
