Which sump gasket
Old Sep 12, 2010 | 02:14 PM
chrisa3's Avatar
chrisa3
Default Which sump gasket
My 2wd sapph is bleeding heavily from around the sump. Bolts keep working themselves loose, and it looks like its had several previous attempts to seal it over the years. Its a 200 block with a 2wd sump.
Does anyone know the best gasket to use, and if you can get the sump off in situ ??
Thanks
Old Sep 12, 2010 | 04:14 PM
Yes the sump comes off in situ, after lowering x member etc to clear.
I've just installed a cometic, heard a lot of good things about them, with loctite 5900 around the ends of the half moon seals.
Are you 100% sure it's the sump, the oil pressure switches leak and spray oil all over the side of the block(as they point upwards) and this runs down and finds it's way all around the sump esp that side.
My switch leaked from between the plastic inner part(with the terminal in the middle) and the metal outer case part.
Old Sep 12, 2010 | 06:10 PM
chrisa3's Avatar
chrisa3
Im not sure to be honest. I cleaned it all off, and it seemed to be coming from the where the oil return from the turbo goes. I cleaned the oil off, put a bigger jubilee clip on the pipe and a bit of gasket sealer around the base where it joins the head/block. Seemed to be fine for about 2-3 miles, then checked when i got back and leaking again. seems to be from the exhaust side. cant see any leaking from the other side much. its mainly driping from the crossmember / steering rack.
doing my head in fix one thing, then something else breaks.. is this the general rule of cosworth ownership. im only 2 weeks in and im starting to loose hair already.
Old Sep 13, 2010 | 02:07 PM
NO they can be totally reliable, unfortunately a lot have been through hands of bodge artists or people, who couldn't/afford to maintain them.
I would check the gasket between the turbo and the drain pipe on it, if leaking around here it will dribble down the whole pipe on the outside.
Old Sep 13, 2010 | 03:04 PM
chrisa3's Avatar
chrisa3
It was leaking from here previously, and replaced the gasket. Im gonna remove the engine and and sell the rest of the car,as I only bought it for the engine in the first place. Then I can get a better look at it and replace anything that needs fixing while its out.
Thanks for the advice
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
Iain Mac
Sep 30, 2015 09:39 PM
DAZZER
Sep 30, 2015 08:43 PM
youngben
Sep 27, 2015 09:37 PM
