clifford keeps going off
Old Jan 21, 2005 | 01:38 PM
percybigun's Avatar
percybigun
Twistin me melon man
Default clifford keeps going off
i have a clifford 500 alarm which makes a fault code bleep when armed after driving in the heavy rain - or if i use the headlight washers alot. then a bit later on after arming the alarm is set off.
i assume its the water going on the bonnet switch, causing the probs.
what can i do to the switch, any ideas?
Old Jan 21, 2005 | 04:02 PM
matts1's Avatar
matts1
Had the same problem with one everytime it rained heavy, I think the sensitivity can be altered but not sure how, may need to contact a dealer to ask how. drove me mad
Old Jan 21, 2005 | 04:42 PM
Steve Escos's Avatar
Steve Escos
Had a similar problem changed out 3 switches. In the end got the dealer to move the switch on to a bracket off the inner wing further up out of the way of any water.( if that makes sense)
Old Jan 21, 2005 | 05:31 PM
Moonie's Avatar
Moonie
You can cover the switch in low temp grease or vaselene to prevent water entering and bridging the contacts.
Old Jan 22, 2005 | 08:46 AM
SS1's Avatar
SS1
proximity sensor turn it down mine bleeps in heavy rain NOT CLIFFORD
THOUGH ..but still the same wires ..
is yours microwave or ultrasonic
Old Jan 28, 2005 | 05:23 PM
Damo V's Avatar
Damo V
bonnet switch... read above for resolution
Steve Escos
Alloy wheels and ICE for sale
14
May 8, 2019 02:45 PM
76
Jul 2, 2005 11:38 PM
SapphyMike
May 27, 2005 12:07 PM
stew205
13
Mar 29, 2005 11:16 AM
wildheart
15
Aug 7, 2004 12:07 PM
