Setting up solid lifters
Old Jul 21, 2010 | 08:10 AM
haz87's Avatar
haz87
Default Setting up solid lifters
Can anyone give me a point by point walk-through on how to set up solid lifters? Got a newman cam on its way and want to get it fitted this weekend before my kent finishes eating itself up
Old Jul 21, 2010 | 08:30 AM
Rs Cosworth 1's Avatar
Rs Cosworth 1
RS for life
Surely your better letting a good reputable tuning company set them up!?
Old Jul 21, 2010 | 05:29 PM
haz87's Avatar
haz87
I've done everything else for the past 5 years so i'm happy to take on this.
Old Jul 21, 2010 | 05:41 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah bit overkill for just setting the lifter gaps! lol
Quick guide....
1. Bring cam lobe to top, rotate cam 180deg
2. Insert lifter
3. Fit rocker arm and TORQUE nut up
4. Meassure gap
5. Remove lifter and adjust
6. Repeat from point 2.
Old Jul 21, 2010 | 05:43 PM
haz87's Avatar
haz87
Are the lifter gaps in the info that comes with the cam kit karlos? Should be arriving tomorow so haven't got anything to go on yet
Old Jul 21, 2010 | 05:44 PM
haz87's Avatar
haz87
And how long did it take you to do when you set yours up all in?
Old Jul 21, 2010 | 07:20 PM
project rs's Avatar
project rs
if it's your first time setting one up allow a good 4 hours and a vernier helps so if you know you are say 0.5mm to big measure it with vernier and adjust measuring till your desired size is obtained lock of nut and put it back in engine for last double check saves you having to put it in engine to see if you've moved it enough as the amount you'll be moving will be so minimal and not visable by eye
Old Jul 21, 2010 | 07:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes mate it does.
1hour 15mins with the head off
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 27, 2015 04:55 AM
37
Sep 17, 2015 05:05 PM
Fudgey
Sep 17, 2015 01:06 PM
gcfcos
88
Sep 15, 2015 03:48 PM
