wasted spark problem?
Old May 30, 2010 | 01:03 PM
benporter's Avatar
benporter
Default wasted spark problem?
ive got a problem with my wasted spark cossi
its not firing on cylinder 1 and 4 ,
ive swapped the amps over so there fine.
if i disconnect a certain one the car keeps running on 3 and 2,
ive checked plugs leads and injectors, they all seem fine.
any suggestions??
cheers
Old May 30, 2010 | 01:08 PM
KSA-Cossie's Avatar
KSA-Cossie
coilpack ?
Old May 30, 2010 | 01:12 PM
benporter's Avatar
benporter
there seems to be a spark when i take them out ?
Gazzonator's Avatar
Gazzonator
Gary Krishna
I would say it's either a coil pack gone faulty or you're not getting the switched earth from the ECU to one side of the coil pack.
Check this by disconnecting the plug and using an LED type circuit tester, put the clip end of the tester to the positive on the battery and the probe to either the outer terminals of the plug. You should have the LED flashing. If there's no flash on one of them, you either have a ECU or wiring issue.
If they're flashing as they should, I would say it's a coil issue.
Old May 30, 2010 | 01:16 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
If you have a spark present, is there fuel getting to the cylinders?
I'm not 100% sure but aren't the injectors batch fired? If so, 1&4 will fire at the same time. Could possibly be a phase sensor issue perhaps?
Old May 30, 2010 | 01:21 PM
benporter's Avatar
benporter
cheers i look now
are 901c plugs ok?
Old May 30, 2010 | 01:28 PM
benporter's Avatar
benporter
it seems to be fucking the plugs on those 2 cylinders after a couple of minutes of running????
Old May 30, 2010 | 02:18 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Fucking the plugs up as in covered in fuel or soot?
Old May 30, 2010 | 02:20 PM
benporter's Avatar
benporter
Soot i think, looks like its the lambda , ive another set of plugs and there still like new with it disconected
cheers
Old May 30, 2010 | 02:26 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Hmm........... Weird. I would have thought if it's a lambda issue it would be doing it on 2&3 as well.
Old May 30, 2010 | 03:33 PM
saffcosworthproject's Avatar
saffcosworthproject
wat make of coil is it and wats the part number?
Old May 30, 2010 | 04:22 PM
benporter's Avatar
benporter
No idea its the msd kit one,
they all were fooked just more noticeable on 1 and 4 , defo seems to be that as its ran fine all day with it disconected
Old May 30, 2010 | 06:00 PM
KSA-Cossie's Avatar
KSA-Cossie
I'd bell MSD ben and see what stu says,did you buy it from them as part of the kit ?
Old May 30, 2010 | 06:04 PM
benporter's Avatar
benporter
ive pmd stu, i think i need a new sensor , i got the chip changed to closed loop when i had the drive board fitted, at its still the original
Old May 30, 2010 | 06:06 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
99% certain its the ignition amp Ben. Had same problem and changed everything only to find it was ign amp.
I'm guessing its sparks all 4 on cranking, but drops to 2 when running ? ?
KSA-Cossie's Avatar
KSA-Cossie
I'd e-mail him to be sure aswell ben.
Old May 30, 2010 | 06:07 PM
benporter's Avatar
benporter
Yes rich , but only after a couple of mins running?
Old May 30, 2010 | 06:08 PM
benporter's Avatar
benporter
if i leave it idling , you can here the cylinders drop off as the plugs fuck up
Old May 30, 2010 | 06:10 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Yeah thats what mine was doing
2 new amps fitted and its spot on now
From Stu's email:
Hi Rich,
The only items that are cylinder specific are the amplifiers, sub loom and ECU.
Best Regards,
Stewart Sanderson
I'd swapped ECU and fully line checked the loom, so amps were only other possibility
gtinutter's Avatar
gtinutter
ben m8 thought you gt this cossie fixed from somewhere in blackpool m8 is it still not right like m8
Old May 30, 2010 | 06:12 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Does it do it with fresh plugs ? ?
Old May 30, 2010 | 06:15 PM
benporter's Avatar
benporter
Yep its eaten about 3 sets now
it is/was fixed im just ironing out all the lose ends now and this seems to have cropped up
Old May 30, 2010 | 06:20 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Yeah i went through 4 sets
DixieTheKid
11
Jun 6, 2020 11:20 AM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
DixieTheKid
Sep 14, 2015 09:04 PM
RSBryden
Sep 6, 2015 08:39 PM
