Focus RS Denso Plug Type???
Old May 9, 2010 | 12:59 AM
Irish aRSe's Avatar
Irish aRSe
Default Focus RS Denso Plug Type???
As above what is the correct part number for the Denso Iridium Plugs? I think it's ITV24 but can anyone confirm???
I checked the Denso site but the Focus RS is not listed only the SVT
cheeRS
Old May 9, 2010 | 09:47 PM
TomStarkey's Avatar
TomStarkey
ITV20 I think
http://www.sparkplugs.co.uk/pages/pr...m-cars-ccp.asp
Old May 15, 2010 | 07:56 PM
R5AAL's Avatar
R5AAL
Wouldn't bother with denso's mate, lots of stories about failures of plugs which ends in tears, but it's either 24s or 27s but depends on engine spec. Stick to standard for items.
Old May 15, 2010 | 10:53 PM
Irish aRSe's Avatar
Irish aRSe
What are the best plugs to run so???I thought the Denso were the daddy of plugs to use, did not realise there had been some disaster stories!
Mods are Gen 2, forge re-circ, decat exhaust, tubular mani, DS Race +
Old May 17, 2010 | 10:45 PM
nightstar's Avatar
nightstar
Noooooo stick to the original ford ones you can't beat them
Old May 18, 2010 | 12:08 PM
oilman's Avatar
oilman
As already said, Denso ITV20's are the ones to go for and a very good plug http://www.opieoils.co.uk/p-4117-den...lug-itv20.aspx
Guy
Old May 18, 2010 | 12:27 PM
COCHYN's Avatar
COCHYN
I'd stick with ITV-22's, spot on for mild modifications on the engine you'll inevitably put on. I had these in my Focus Turbo and old Focus RS, both over 300bhp.
Old May 30, 2010 | 09:54 AM
jonnyfocus's Avatar
jonnyfocus
Denso ITV 22 are for the standard engine not the 20's.
I have standard ford ngk's regapped to 0.8mm and i'm running 326bhp 401lbft with no issues.
Old May 30, 2010 | 04:23 PM
oilman's Avatar
oilman
According to Denso, ITV20s are the standard ones
http://www.globaldenso.com/cgi-bin/g...me=&cc=&FF=100
ITV22s won't be a problem though
Old May 30, 2010 | 04:27 PM
COCHYN's Avatar
COCHYN
20's are for standard, 22's are for anything slightly over 300 bhp.
Old Jun 7, 2010 | 09:46 PM
jonnyfocus's Avatar
jonnyfocus
I've saw that before, its an american lad that said that 22's are for standard engine, he is into his denso plugs
Did you look at what it recommends for the st170? It wouldn't need a colder plug that the frs.
Old Jun 8, 2010 | 12:49 PM
oilman's Avatar
oilman
Oddly it says ITV24 for the ST170
Old Jun 9, 2010 | 10:15 AM
hineho87's Avatar
hineho87
Sorry to jump the thread but is it better to stick to ford plugs or to use denso iridium or NGK platinum plugs on my 1.8.
Mine are due a change and wondered wots best go for? Iv got full exhaust and induction mods, plus Kent cams/verniers if this makes any difference
Thanks
Matt
Old Jun 9, 2010 | 12:48 PM
oilman's Avatar
oilman
Hi Matt
I'm not sure what plugs are originally in the car, but the Denso and NGK iridium plugs are very durable, especially if the engine has been modded.
Tim
Old Jun 9, 2010 | 01:27 PM
hineho87's Avatar
hineho87
Hi Matt
Tim
PM'd
Old Jun 9, 2010 | 01:32 PM
szabyk RST's Avatar
szabyk RST
ITV 24 working fine with 600+
Old Jun 9, 2010 | 08:18 PM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
Standard ford plugs also working fine at 522bhp
cheers paul
Old Jun 27, 2010 | 09:31 PM
jonnyfocus's Avatar
jonnyfocus
What have you them gapped to and how often do you change them?
Old Jul 5, 2010 | 10:16 PM
crazycage's Avatar
crazycage
cheers paul
same as me but they do need to be changed every 2k to be on the safe side i found.
p-s thats at around 370hp
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Fordmad!
Sep 26, 2015 05:24 PM
CossieRich
30
Sep 8, 2015 10:08 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
