2.0 ghia vs 2.0 st170
Old Apr 22, 2010 | 10:10 AM
Ghia-Buckleyn's Avatar
Ghia-Buckleyn
Default 2.0 ghia vs 2.0 st170
Basically i've got a 2.0 ghia focus (i think it has 130bhp) how would i make it match the bhp of a st170 or this not worth doing considering the money needed to get the power.
Nathan
Old Apr 22, 2010 | 12:03 PM
TomStarkey's Avatar
TomStarkey
I think 150bhp is about the limit for standard 2 litres without spending Ł1000's
Old Apr 22, 2010 | 12:15 PM
Chris69's Avatar
Chris69
yeah i agree, 150 bhp is about all you'll see with bolt on mods then you'll need to change the cams and go to T/Bs to see more really.
150ps will see you keeping up with most st170s though.
thats assuming all ghias have quite a short ratio MTX box like my ghia estate does so its pretty quick through the cogs(it does 130 on my gps very close to 6k in 5th)
Old Apr 22, 2010 | 12:21 PM
Sp3no's Avatar
Sp3no
Most St170's only have 150BHP so if you can get 150 out of yours you will be all over an ST170
Old Apr 22, 2010 | 01:49 PM
CaysE's Avatar
CaysE
Most? There are some that may be underpowered, but most should be making near 165-170bhp.
Old Apr 22, 2010 | 02:17 PM
Ghia-Buckleyn
Alright thanks for the comments 150bhp sounds good enough , so what will i need to get to 150bhp (being cost effective) i.e the most power for the minimum amount of money
Old Apr 22, 2010 | 03:15 PM
TomStarkey's Avatar
TomStarkey
U can get it chipped for under Ł250, that'll get you 15hp I guess. Then there's a K&N filter for Ł40-60? then other stuff I don't really know too much about
Old Apr 22, 2010 | 04:42 PM
Ghia-Buckleyn
Another quick question, I'm thinking of getting st alloys will Mondeo st200 alloys fit my focus (mines a '00 x reg)
Old Apr 22, 2010 | 05:00 PM
pani_k's Avatar
pani_k
PassionFORD Member
Seem to have been writing this for a lot of members recently...I recommend the following in this order:
1) ST170 4-2-1 Manifold or similar by Millitek or Piper
2) Full cat back from Millitek, Piper, Scorpion, Blueflame, Magnex etc.
3) Enclosed induction e.g BMC CDA or Pipercross Viper. Alternatively source a ST170 airbox complete or just the bottom half, ST170 snorkel and 2.0 auto air deflector and fit a K&N panel filter.
4) Evolution Chip flash map or Dreamscience. Don't recommend Bluefin.
The above should see a PROVEN 140-150bhp. 150+bhp if you have a very strong engine (or if the dyno is feeling a bit generous)
Old Apr 23, 2010 | 09:32 PM
woolford's Avatar
woolford
i have all the above plus lightened flywheel and uprated valve springs with fast road cams. slightly higher comp
Old Apr 24, 2010 | 06:53 AM
M1keLR's Avatar
M1keLR
Yes, these will fit your focus
Old Apr 29, 2010 | 08:25 PM
Ghia-Buckleyn
Will a st170 exhaust system fit a 2.0 ghia and will it give me any more power or is it easier to just buy a performance exhaust like a Millitek.
Old Apr 29, 2010 | 08:30 PM
daz-cos's Avatar
daz-cos
my old 170 only made 140 on the rollers
Old Apr 29, 2010 | 09:46 PM
duderacing's Avatar
duderacing
I know it's boring, but have you thought about selling the 2ltr to buy an st170, as most of the parts you'll probably be wanting to fit are already on the st.
I've been really interested in fitting an st manifold, and would also like to uprate the brakes, suspension and interior, which led me to thinking that an st170 would probably end up being the cheaper option in the end.
I know this is only my first post,but I'v been reading quite a bit on the forum, and do know a few things about mod'd/performance motors, so please don't give me too much shit.
Old Apr 29, 2010 | 10:31 PM
Ghia-Buckleyn
The problem from what i've heard on here and other forums is that a lot of st170s only have around 150bhp and cost around Ł3k more than a standard 2.0. So if you pay for mods on a 2.0 you you match a st170 for less. Also i've only just bought my 2.0 ghia about a month ago so i'll probs be keeping for a few years yet lol.
Old Apr 30, 2010 | 06:31 AM
Chris69's Avatar
Chris69
horses for courses but i do think teh ST command quite a large premuim over the 2litre considering relatively small performance gains.
Go with the Pani_K's list thats eaxctly wot i plan to do with mine, bluefin aren't that bad either but you will need to get it RR'd and the map adjusted at least once lol.
Old Apr 30, 2010 | 05:02 PM
duderacing's Avatar
duderacing
I wouldn't want to deter anyone from modifying their car, I just think that most area's have been made to suit the power on an st, and the resale would see you loose less money than on a mod'd 2ltr.
Having said all this, I always liked modifying to my own needs, and many of the aspects which the st is superior in, may not matter to you.
Do you just want to match the power, because I've seen a few posts from people who claim to be matching st170 performance from 2ltrs with pretty much pani_k's list.
Old Apr 30, 2010 | 06:14 PM
ricky_2006's Avatar
ricky_2006
some are less than other from what every1 sayd.
but i havent got a clue what mine is running.
best thing i can think of its taking it to a rolling road and get them to tune it. SIMPLE
Old Apr 30, 2010 | 07:34 PM
Ghia-Buckleyn
Personally i don't think the st170 worth the extra Ł3k, i mean if you don't like modding that's ok but the standard 2.0 isn't a far cry from the st170. If you want a fast standard mk 1 i would save up and get an RS.
Old Apr 30, 2010 | 11:02 PM
TomStarkey's Avatar
TomStarkey
I'd also suggest uprated brakes to stop you if your planning to go faster using your 30 extra horses
Old Apr 30, 2010 | 11:46 PM
phil_focus's Avatar
phil_focus
i have a 2l w reg zetec with focus central 4-2-1 (looks identical to milltek on the pics but dunno about bore size), milltek cat back (for the 2l which is 2 1/4 inch iirc rather than 2 1/2 in for the st170), magnecore kv85 leads (i recomend as mine runs smoother with them) and k&n pannel with uprated cold air feed to air box (chopped the fins of the intake on the box and hose cliped some flexi tube on going to lower grill.
she made in march 117bhp at the wheels, 149bhp at the fly (21% transmition loss - that seem a bit high or not for an mtx75 box??) and peak torque was about 150 lbft
the rolling road was done at aldon automotive who also have an engine dyno which they can use to see how accurate the rollers are and aparently the figures are pretty darn close.
all this btw is on the standard map and i recomend the st170/st170 knuckles with mondeo mk3 callipers brake upgrade.
next step to get st170 power would be custom remap and that should see about 160 and with cams 170+bhp but that i think is the limit of the standard intake manifold from what i've heard.
i personally (if and when funds allow) will be going throttle bodies with stand alone engine management next and see what i can get out the standard engine and then try some cams. should get somewhere near 185-190bhp maybe.
oh and my engine has coverd almost 104k...they only get better with age these zetec e's, just regularly service them 8)
Old May 4, 2010 | 12:20 PM
woolford's Avatar
woolford
inlet is same as mk1 rs aint it and thats forced imductiom
Old May 4, 2010 | 02:16 PM
phil_focus's Avatar
phil_focus
yes the inlet on the 1.8 and 2l are the same as the rs but the rs is forced induction. for n/a from what i've heard in the past the standard manifold gets restrictive at 170+ bhp
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
The Enigma
Sep 29, 2015 10:31 AM
Marv888
Sep 26, 2015 03:44 PM
