GoKart rebuild GSXR 1000cc finished VID NOW ADDED!!! ALSO FOR SALE £3750
Old Feb 28, 2010 | 04:45 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
Default GoKart rebuild GSXR 1000cc finished VID NOW ADDED!!! ALSO FOR SALE £3750
Some here may remember last year when I wrote off my mates go katr trying to get an extra secong out of a double lap at the end of a long day of fun at a sprint track lol
The crash http://www.youtube.com/watch?v=cGNqI9JPZrg
well I've got the track booked again for end of April so rebuilds under way -
Pic's and words from my mate -
Originally Posted by timbhp
Its started as some of you know ive got a gokart with a gsxr 1000cc bike engine and a lot of one off parts i had to make that we took to curbourgh which went very well for its first time out,
And some one who shall remain nameless stuffed it into the bank and reshaped the chassis slightly thanks kev, oops wasn't going to say ,
So this is the rebuild of it
pics up soon
just setting up old and new so you can see the changes and i have got specs before i start cutting ,so i can add in longer chassis rails and extra support rails to take the power,
more pics before i start long bar is so i can line up both chassis
cut chassis
spigots turned down so can tap inside tubes for tight fit before welding 7 of these reqd
spigots in place
chassis tubes to extend chassis 18"
turned drilled and taped inserts for rear chassis tubes to take rear bumper
rear inserts in place
this saves alot of work with hack saw
all tacked together after a lot of checking and double checking
pic with rear axle in place to check its all square and true, the tubes next to it are for the next bit of the chassis to stop flex and to give a bit of side impact protection which you will see on the next lot of pics
thats it for now.
More updates soon
Old Feb 28, 2010 | 05:13 PM
bad boy rs's Avatar
bad boy rs
that must have hurt
Old Feb 28, 2010 | 05:56 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
it did mate lol broke a few ribs on it.
Old Feb 28, 2010 | 07:59 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
awesome fella !!!
so how long is the entire kart say over a standard kart,
he going to start selling the chassis ??
beef
Old Feb 28, 2010 | 08:09 PM
smitsturbo's Avatar
smitsturbo
i would love to build one of these, as beefy says above
Old Feb 28, 2010 | 09:39 PM
timbhp's Avatar
timbhp
i have had to add an extra 18" into chassis,
Old Feb 28, 2010 | 10:57 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
beef
No mate, but the entire Kart will be for sale once rebuilt and tested again on track so this rebuild thread will be linked to for sale adds so people will be able to see the build of it this time
Old Feb 28, 2010 | 11:06 PM
COLEYST200's Avatar
COLEYST200
you lot are mad but you have to love it at the same time
Old Feb 28, 2010 | 11:13 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
Brummies for ya mate
Old Feb 28, 2010 | 11:18 PM
COLEYST200's Avatar
COLEYST200
to right mate
Old Mar 7, 2010 | 08:53 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
Another update from Tim
Well have spent more time in workshop over the last week,as time is going on and test day is getting closer
and i need to get all built up then striped powder coated and rebuilt ready here are some more pics ,
ebay purchase tube notcer just arrived so here are a few pics
they say it will notch tubes up to 2"
these are a few tubes i have done works great
axle in this shot is spare
all tubes tacked in place
string is centre line
tubes now welded in
axle with rear one off sprocket and mtg hub made to my ratio and spec
also centre suport bearing on
even the dog has got to check up to make sure i am doing a good job
you can see center bearing holder which will have mtg plate welded to both tubes below it
hubs on axle and wheels ready for fitting
wide wheels and 6" dia not your normal 5"dia with medium compound on rear and soft on front
looking wide now
this is what you call a short chain ,shorten,d down gsxr 1000 chain
starting axle centre suport mtg plate
1" hole to take centre bearing
mtg now cut ready for tacking
centre mtg finished
this is the small power plant
2004 gsxr 1000cc with only 4000 miles on it
fuel injection
just offering up to locate engine mtg
some were close to position
mtg for engine side plates only 3 mm thick so need some strengthing plates
strengthing plates ready to weld in place
now welded
engine mtg made and welded on
engine on rear mtg with good old block of wood up front
as you can see the engine is well back
chain in line
throtle bodies and injectio set up
electrics to be sorted when rest of stuf bolted on
one off header tank
titanium down pipes cut and rewelded into shape then wraped to stop cooking your back
:thumbup1:
down pipes fitted you can even still change oil filter with out droping down pipes
works its way round everything
into this carbon race can very light
spits flame out on over run
not sure this means the kart or the exhaust
thats all so far ,will be working on it in week and next weekend so more to come just got to keep the pace up
Old Mar 7, 2010 | 08:57 PM
TOMMY_RS's Avatar
TOMMY_RS
SHITE!
thats guna go like fuck lol.
Old Mar 7, 2010 | 09:32 PM
Rsmat's Avatar
Rsmat
awesome mate.
Old Mar 7, 2010 | 09:45 PM
COLEYST200's Avatar
COLEYST200
nice work mate
Old Mar 7, 2010 | 10:03 PM
boothy's Avatar
boothy
Shit hot
Old Mar 8, 2010 | 07:12 AM
Scott-rs2k's Avatar
Scott-rs2k
s**t the bed lol that be a bit of a machine eh
Old Mar 8, 2010 | 03:51 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
lol Tims the mentalist behind this lads and I was slightly tapped to have driven it.
Vids in the 1st reply on here also if you havent seen it.
GSXR 1000cc Go-Kart will be for sale once rebuilt and test driven on track, would of been for sale last year had I not bent it
Old Mar 8, 2010 | 04:35 PM
-beefy-'s Avatar
-beefy-
fucking said it once , ill say it again
mental
Old Mar 8, 2010 | 05:32 PM
timbhp's Avatar
timbhp
its gear'd the same as the bike so it should do about 180 mph
if you are mad enough and revs to 12.500 rpm with about 170, 180bhp with remap and end can, at flywheel ,
on the last outing was getting to 5th gear and 10,500 rpm down curbourgh sprint track and still another gear to go , but over the bumps it was just lifting enough to allow wheels to spin so when came back down the wheels still spinning ment you were driffting at about 130/140mph,realy great fun tryin to keep it in line.
Old Mar 8, 2010 | 05:41 PM
H7 CYA's Avatar
H7 CYA
Fucking mentalist!!
Old Mar 8, 2010 | 06:03 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
That was the best bit for me pmsl but I cant even remember thinking about it as it was all lightening reaction time tbh, you just do when ya at them speeds.
would I do it again? NO
Old Mar 10, 2010 | 07:43 PM
woolford's Avatar
woolford
cracking work
Old Apr 1, 2010 | 11:40 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
Count down continues lol has to be reayd for track session I have organised on the 29th of April lol 4 weeks and counting!!!
Got a bit more done just not had time to upload more pics so here we are,
turned from bar to make end plugs on chassis
cut in half
in this shot you can see tube that needs pluging 1 on each side was were front hubs went
getting new front mountings ready for welding in place
jig made to hold in place
front corner tacked in position
both corners in place
side rails to help strengthen chassis along with x bracing
cut origanal steering arm of
turned down and re bored bearing seat as would not fit front hub
turned and reamed sleeve
made seat mountings ready to weld on frame and spacers
mountings in place
steering column mounting bars in wrong position holding to 1 side
so they have gone
turned these
got the column tubes of the old cart
welded on mountings and slide over new tubes
now got center position for column
from front
front hub with new adaptor to take wheels as different pcd
another pic
alloy side mounting for top engine mount
heat sheild to help keep the pilots back a bit cooler
one off header tank, mounts on upper engine mounting along with fuel pressure reg
Old Apr 1, 2010 | 11:59 PM
escort1989uk's Avatar
escort1989uk
been busy what else needs to be fabricated going to be stronger this time for sure
Old Apr 2, 2010 | 12:01 AM
Red16's Avatar
Red16
Cool project... it'll be one hell of a toy
Old Apr 2, 2010 | 09:43 AM
COLEYST200's Avatar
COLEYST200
im loving it mate all most done now
Old Apr 2, 2010 | 11:04 AM
16vzetec's Avatar
16vzetec
i love the idea of these as the are very fast but they are also very dangerous, my opinion is (from a bloke into bikes and knows sod all about go carts) is that these need some suspension, there is no give over even little bumps and with this kind of bhp per ton its gonna make it one scary ride.
is there not a way of making a pivvoting chassis so the front and rear can flex a bit all be it not independatly left and right, just back and front slight movement from the center part of the chassis?
it will give it that slight movement these need to not be lethal imo.
even if its just some rubber that compresses a bit over bumps to allow movement.
if i wind my r1 suspension up rock hard it skips about and handles crap, if its got movement its perfect
Old Apr 2, 2010 | 11:06 AM
xrmalin's Avatar
xrmalin
Thats going to be amazing 180mph with your arse 2 inches off the floor do you have to wear nappys lol
Old Apr 2, 2010 | 03:52 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
when all mock ups finished chasis will be off to powder coaters and all body pannels etc will be off to paint
youll all love the paint choice aswell, just to note, I will not be driving it again this year as a few have asked
I had my fun last year, its not any faster this year just rebuilt on new improved chasis and better finishing done and me driving it this year would be asking for trouble as it will be for sale after testing session end of the month
Old Apr 2, 2010 | 06:59 PM
andy escos's Avatar
andy escos
madness utter utter madness but i like it lol
Old Apr 2, 2010 | 08:25 PM
Zetecfiesta's Avatar
Zetecfiesta
thats just nutty!
Old Apr 2, 2010 | 08:35 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Thats gonna go like shit off a shovel
Bit like this R1 150bhp:
http://www.youtube.com/watch?v=tWKNh...eature=related
Old Apr 2, 2010 | 09:35 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
heres me and Tim having a bit of fun on it befor the track last year
http://www.youtube.com/watch?v=zzRdn...eature=related
Old Apr 2, 2010 | 09:42 PM
COLEYST200's Avatar
COLEYST200
fucking mad video mate
Old Apr 2, 2010 | 09:57 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
ace that vid enit mate
that was me n Tim giving it its first ever run on full poke, us checking the steering ran true
Old Apr 2, 2010 | 10:11 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Pivoting chassis in the middle? that'd make it alot worse! They don't need suspension, go watch some 125/250cc gearbox kart races, ALOT faster round a track than this'll ever be, and they don't have sus Oh, they're faster than bikes around alot of tracks aswell...
Old Apr 5, 2010 | 01:55 PM
timbhp's Avatar
timbhp
Just to let you know this kart handled fine around curbourgh sprint track i cudnt fault it on track, before kev stuffed it in the bank,And it will again after this rebuild, the low tyre presures help with small bumps
it is so much fun you dont care ,about anythin els well i dont anyway,it is just abit wild when you mess about doin donuts and stuff
Old Apr 5, 2010 | 07:30 PM
GINGExR2 T's Avatar
GINGExR2 T
Thats just plain metal
Old Apr 5, 2010 | 08:40 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
OK, OK, they all know I stuffed it
Old Apr 11, 2010 | 10:18 AM
Minirotty's Avatar
Minirotty
Lucifer II - 666
update coming now, replying just to get it to page two as pics are a killer in one page lol
