engine rebuild questions
Old Jan 8, 2005 | 04:53 PM
AJC's Avatar
AJC
Default engine rebuild questions
can any one tell me a typical price to rebuild a escort S1 engine,
been told today 2 grand to drop my car of, pick it up 3 weeks
later with a rebuilt engine,
can some one let me know what they paid and to what spec,
my friend whos a mechanic said he would do it,
i.e fit new pistons etc for me in my garage at home, i know
he can do it cause he is currently doing one. i just would not have receipt
to prove a rebuild
ta
Old Jan 8, 2005 | 06:18 PM
sime73's Avatar
sime73
tbh mate, the engines are pretty basic and if your handy with the tools u can do it yourself...as i am
Old Jan 8, 2005 | 06:30 PM
AJC's Avatar
AJC
thought about it, cant see any one believing me about it having one though if
ive no receipts (for when i come to sell it) , i suppose i can show them receipts
for engine parts, but not only that, it will take me longer than what i want the car to be of the road for
Old Jan 8, 2005 | 06:38 PM
UBster's Avatar
UBster
my engine rebuild cost Ł1200 inc oversized low comp mahle pistons, heavy duty bearings, balanced crankshaft and a kent cvh35 cam.. + a few more bits but I'll have to dig the receipt out that was about 5 yrs ago though
Ł2000 doesnt sound overpriced tbh who gave you the quote?
Matt
Old Jan 8, 2005 | 07:11 PM
DazC's Avatar
DazC
Mine was in excess of Ł4500 but I did have something a little special built!
That was just a built unit and not installed into the car.
2k to remove, rebuild and refit should be about right if it is done properly and corners are not cut.
Old Jan 8, 2005 | 11:38 PM
AJC's Avatar
AJC
the quote was from MSD in blackpool, i aint entirely sure what to do,
thinking of takin engine out my self in a couple of weeks and giving it to a
local rebuilder with a very good reputation. i was just goin to replace pistons, i dont know about any thing else
any suggestions?
thanks in advance
Old Jan 9, 2005 | 09:13 AM
james_birch's Avatar
james_birch
yeah dont just do pistons! you gotta do the shells and everything aswell and an oil pump!
Old Jan 9, 2005 | 09:14 AM
james_birch
and i wouldnt have no prob paying MSD 2k for a rebuild!
Old Jan 9, 2005 | 10:55 AM
Smiggy's Avatar
Smiggy
Try and get a hold of most of the parts yourself - you'd be surprised how much that will take off your final bill as you will only be paying for labour. Garage i was going to use were going to buy a new set of pistons for mine for Ł400 - I got a brand new set on ebay for Ł150. Ł250 already saved on just one item.
You should be able to pick up some good deals, especially at this time of year.
Pistons:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=4516620945
Old Jan 9, 2005 | 12:16 PM
DazC's Avatar
DazC
any suggestions?
thanks in advance
MSD will do the job properly. If you want to save money then whip the donkey out yourself and drag it up there in one of your vans on Saturday and just let them rebuild it. You will get a nice booklet documenting the spec and what work has been done plus a CD with pictures of the engine in various states of rebuild for your history and then refit it yourself, take the car back for a basic set up and then run it in. Then one final trip for a full set up...
Your other option is to ask Richard with the 2wd Cossie if he will build it for you....
Old Jan 9, 2005 | 04:18 PM
AJC's Avatar
AJC
any suggestions?
thanks in advance
Old Jan 9, 2005 | 04:20 PM
AJC's Avatar
AJC
that went a bit wrong,
heres what i meant to put,
that sounds like a bit of a better idea, make job cheaper too, would
MSD not mind if i bought those pistons of ebay that smiggy has
put a link up for, save some money, or would they rather they sorted out that side
of things,
thank you
Old Jan 9, 2005 | 06:02 PM
james_birch
your the paying customer you tell them what to do! if they want ya money they will do as you ask! BUT the will addvise you on the BEST corse of action! and of corse it pays to listen! but i mean even MSN ie. stu will know where ya coming from if you can save Ł250 on the rebuild price!! just you wont have nothing to say if the pistons go wrong!
Best thing to do is ask! they cant tell you what to do! but will give you addvice!
Old Jan 9, 2005 | 06:13 PM
PaulT's Avatar
PaulT
My rebuild cost was 450 for pistons and rebore 120 for the crank grind supplied with shells, they put the pistons in the block i put the crank back in and built it up as said earlier its a straight forward engine if you have a haynes manual. Not a mechanic by trade just for fun.
TTFN PaulT
Old Jan 9, 2005 | 07:17 PM
DazC's Avatar
DazC
of things,
thank you
I supplied MSD with pistons, rods, oil pump and water pump so I can't see an issue unless some bits you get are wrong.....
Pistons are not that expensive anyway unless you want forged ones.....
Old Jan 17, 2005 | 09:01 AM
Stu @ M Developments's Avatar
PassionFords Creator
Its interesting how a couple of peeps on here reckon a "Rebuilt" motor just consists of some pistons and shells
Top of my head, CVH build to STD spec:
Machine work usually required:
Rebore existing block
Bore Honing (cross hatch)
Crank grind / polish
Dynamic Balancing
Decompress pistons
Surface Grind Flywheel
New partsalways fitted
Mahle Pistons and rings.
Performance full cam kit.
Crank & big end bearings.
Thrust washers. (U&L)
Oil Pump.
Water pump.
ARP Big end bolts.
Genuine Gaskets and seals.
Genuine Head Bolts.
Cambelt. (Gates OE).
Cambelt tensioner.
Thermostat and seal.
Dash temp gauge sender
Ford 071 plugs
8 new rocker locknuts
Block to turbo oil pipe
Mineral Oil and OE filter
Labour on top as i have a family to feed the same as you folks
You do, as Daz kindly points out, get a CD with lots of pictures of your engine build in various stages of strip and build.
On top of that lot, which pans out around Ł2200 all in... you may have to have:
Full Cylinder head overhaul:
Pressure test
8 Valve guides
8 valve seats
8 valves re-cut to seats
Surface skim
Block Reface.
Head reface.
Optional upgrades:
Stage 3 cylinder head
Duralloy vernier timing pulley
Cosworth forged pistons.
Steel H section Connecting rods.
Steel crank.
Alcon 6 paddle clutch.
The list goes on depending on what you want to do and achieve, but the point im making is when someone offers to whip teh sump off on your drive and bang some new shells in, a "Rebuilt" motor is NOT what you have
Old Jan 17, 2005 | 09:06 AM
james_birch
very good answer stu! makes good reading!
do i get discount now!? ...lol...
Old Jan 17, 2005 | 09:07 AM
Daz,
Normally if a customer supplies his own engine parts i wont warranty the engine at all as a failure can wreck other parts that i DID supply, leading to problems.
I made an exception in your case as the parts used were of a higher than normal std and im willing to take the risk based on that, but i wont normally.
Hope this helps.
James,
NO
Old Jan 17, 2005 | 10:32 AM
adamS2RST's Avatar
adamS2RST
Oh, I better get saving
Old Jan 17, 2005 | 06:16 PM
AJC's Avatar
AJC
BOOKED MINE IN AT MSD, TAKIN IT DOWN THIS SATURDAY,
GETTING PADDLE CLUTCH AT SAME TIME AS WELL AS TURBO,
INTERCOOLER AND FULL NEW SET OF SAMCOS, POWDER COATING
AND SOME NEW SHINEY STUFF, GOING TO UNDER SEAL THE
CAR WHILST ITS UP IN THE AIR TOO.
Old Jan 17, 2005 | 07:54 PM
james_birch
Well stu you dont hang about do ya!!
let me guess! grs cooler!
ap clutch!
pink powder coated rocker cover!
only joking!
Im 100% sure you will be well impressed!
Now do i get that discount!
Old Jan 17, 2005 | 08:51 PM
DazC's Avatar
DazC
Good choice!
Old Jan 17, 2005 | 08:52 PM
DazC's Avatar
DazC
Originally Posted by Stu @ M Developments
Daz,
6 month warranty has expired now anyway Stu!
I understand TOTALLY where you are coming from though. I actually meant that I don't think you would have a prblem fitting the parts but didn't think you would warranty it.
I need to have a chat with you this week end about my loom and options before e-mailing my requirements back to Pi Research.
Old Jan 17, 2005 | 09:20 PM
AJC's Avatar
AJC
any recommendations on a turbo to purchase?
i was thinking of getting the pace intercooler,
and the powder coating aint PINK,
going for samco blue i think but i have seen some ones
with an RS badge on them which i quite like but dont know
where to get them from
Old Jan 17, 2005 | 09:50 PM
DazC's Avatar
DazC
Not sure on the turbo. I am currently using a totally standard unit rebuilt at Turboforce in Bamber Bridge at 14 psi and it's stood upt to 3800k and 1800k of abuse so far.
They can also build a hybrid as they offered to do mine but I declined as I want to go a different route. Depends how far you want to go...
As for the Pace, I am not sure. If any, the only one of the Pace shite to go for is the full frontal set up as I have heard that these actually perform reasonably well.
I personally run a GRS full frontal twin pass but am unsure if I will be sticking with it at the moment.
Hoses again unsure. Mine were made by Roose Motorsport in plain but shiny black.
Old Jan 17, 2005 | 10:20 PM
james_birch
Turbo speak to stu! it all depends what ya want from your engine!
Hoses! auto specialists (sp)...
and go on! you know you want a pink rocker cover!
Old Jan 18, 2005 | 05:00 PM
AJC's Avatar
AJC
cheers, i have 2 original turbos of a s1 at home,
i will talk to MSD on saturday and see what they say
Old Jan 18, 2005 | 09:29 PM
Rick's Avatar
Rick
Good choice, u'll get a decent engine. I have actually got everything on that list apart from the Alcon 6 paddle..
Old Jan 19, 2005 | 02:20 PM
Turbocharger options depend heavily on final power output required by you. Consider this very carefully as your engines:
Bearing clearances.
Bore Clearances.
Compression Ratio.
Ring pack Gap.
Camshaft Kit.
& Turbo charger.
Will all be specced to ultimately suit this end result. Try to get it right NOW rather than compromise later.
As for powder coating, maybe Ask Daz where he got his done as i think it was pretty good quality and a decent colour too
Old Jan 19, 2005 | 05:44 PM
adamS2RST's Avatar
adamS2RST
Why are the cosworth racing piston crowns flat for the cvh?
Old Jan 19, 2005 | 06:25 PM
They are a CVH base piston and require machining to fit each application.
Old Jan 19, 2005 | 08:15 PM
JesseT's Avatar
JesseT
That's a strange looking S1 water pump. Where is it from and is it with a cast impeller?
Old Jan 19, 2005 | 08:34 PM
adamS2RST's Avatar
adamS2RST
So they are not low compression then?
Old Jan 20, 2005 | 10:34 AM
james_birch
Stu when you build a new engine an fit a high lift cam, (dunno how to word this) do you just fire the new engine up and straight away rev it to 2000rpm for 20mins?!
Or is there another way?!
only a genral intrest question!!
Old Jan 20, 2005 | 10:40 AM
JesseT,
Unsure to be honest as that engine was built a long time ago, its just the only one i had on Photobucket. The customer supplied the pump himself i recall.
adamS2RST,
No, if you fitted them as std you couldnt even bolt the head back on..roflol
james_birch,
Yes, as soon as the engines fired up the engine is taken to and held at 2500 rpm.
Believe it or not, this is easier on the engine than idle speed. Idle is quite a stressfull area for an engine to run at as the valve train acceleration is very low and oil pressure is at its lowest.
Hope this helps.
Old Jan 20, 2005 | 06:52 PM
james_birch
james_birch,
Hope this helps.
thanks alot stu! as said was just a genral intrest question!
I am looking into gettin a rebuild myself soon! (just got some bills to pay )
only thing is people quote prices but only one place i seen so far quotes a drive in drive out price which to be honest i think everyone wants! just no one quotes them prices! understandably full engine rebuilds are a very intermite thing and prices all depend on what the customer wants power wise and part wise!
But having a guide price (i think most will agree) of just a basic rebuild would be nice!
Old Jan 20, 2005 | 07:04 PM
james_birch,
Well, the price i quoted above is for me to do the engine, thats a flat price, sorted period. So get a quote from local garage/mechanic to remove and refit, and your away
Old Jan 21, 2005 | 07:37 AM
james_birch
that including me discount stu! ....
Old Jan 21, 2005 | 10:23 AM
DazC's Avatar
DazC
I got it from a local supplier near me. It's just a reproduction of an origional as IIRC, when I rang Ford for a new one (along with the oil pump) I was told that they are no longer available...
Old Jan 23, 2005 | 08:08 PM
Originally Posted by james_birch
that including me discount Stu! ....
