St170 Problems!! PLEASE HELP :(
Old Jan 29, 2010 | 04:17 PM
leegoodlad's Avatar
leegoodlad
Default St170 Problems!! PLEASE HELP :(
HI
Today i crashed my car and my pride and joy in the snow which is an ST170 and luckly i got away with minimal damage, the worst problem is my sump is now leaking.
Can someone help by telling me what sump pans will fit the st170? for example would a 2.0l sump pans fit the s170? Or even any other sump pans?
Thanks
Lee
Old Jan 29, 2010 | 04:22 PM
johnson_rs's Avatar
johnson_rs
another shetlander! unlucky, whar aboots did du crash at?
i think the st170 sump is different fae the 1.8/2.0 zetec but i might be wrong about dat.
is it a aluminium or steel sump?
Andy
Old Jan 30, 2010 | 04:29 AM
pdfbt40's Avatar
pdfbt40
Any 'Blacktop' (6/98>) Zetec-E sump will fit, including a Mondeo one.....However....
With a genuine Ford Mondeo one, the gap the cat fits into is a bit narrower, so you might need to tune the heatshield. Also its marginally shallower so you need to use a Mondeo oil pick up pipe.
There are quite a few suppliers of 'pattern' Focus sumps now. The price is 1/3 to 1/2 the Ford price.
Martin
Old Jan 31, 2010 | 09:31 AM
alexst0ne's Avatar
alexst0ne
Unlucky mate, the main difference between the regular 2.0 Focus and the ST is the head, so the sump should fit fine
Old Jan 31, 2010 | 09:41 AM
graham c's Avatar
graham c
if its cracked get some jb weld or chemical metal it works fine
Old Feb 9, 2010 | 11:33 AM
leegoodlad's Avatar
leegoodlad
Thanks guys.
For raplcing the sump will i just have to drop the exhaust out of the way? or is there more too it? Im not very cargenic, but after xmas im skint so going to have to do it my self.
Old Feb 9, 2010 | 12:21 PM
RichieST's Avatar
RichieST
Yeah drop the exhaust down a bit, drain out the oil, then undo the bolts and it should come off, might need a tap to get it to shift. Don't forget to clean up the mating surfaces and fit a new gasket when you refit it!
Old Feb 9, 2010 | 01:23 PM
pdfbt40's Avatar
pdfbt40
Think you'll need to drop the cat/decat completely from my experience.
Unfortunately it will take a bit more than a tap to break the pan from the lower crankcase. There's no gasket, it's sealed with silicon gasket compound. Usually its a Stanley knife -> careful chisel use to break the joint.....
Martin
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
Tank Mike
Sep 10, 2015 07:56 AM
