Problem starting
Old Jan 4, 2005 | 09:29 PM
Big AL's Avatar
Big AL
Default Problem starting
Car wont start unless timing is advanced, when catches retard timing and runs sweet as a nut, when warm autochoke cuts off, ticks over nicely and runs well.
Would appear to be a fuelling prob of some sort as try to start and it wants to fire but wont until timing is advanced.
Spark is there all the time (New Dizzy and Coilpack), Fuel pump primes when switch ignition on.
Car is a 1990 ERST, recently undergone full engine rebuild, cam, followers, tappets, head gasket set, bottom end, rings etc.
Always started on the button before rebuild but big ends were rattling and so was the cam hence full rebuild.
Is getting on my tits now, shame I don't have a box of matches handy.
Al
Old Jan 5, 2005 | 05:38 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
engine will be tight so will be slower cranking over possibly, cold start valve DEFFO comming on? if not check it and thermo time switch. try starting it holding the metering flap down a few mm, is it possible its flooding when u turn it over cos engine will be tight? get it started, set up on a RR and take it for a 1000mile drive lol
Old Jan 5, 2005 | 10:34 AM
Big AL's Avatar
Big AL
Cheers chap, I'll check those and repost.
When it starts it's off for a tune and a lap of the M25
Old Jan 5, 2005 | 01:27 PM
Big AL's Avatar
Big AL
Played again with it and would appear fuel is running back from the lines as leave it a couple of mins and it starts but leave it 1/2 hour and she won't start, tries to catch but doesn't, it's as if there is air in the system or fuel is running back down the lines ?
Is there a return valve somewhere to stop fuel from running back when car is switched off ?
Old Jan 5, 2005 | 10:17 PM
armracing's Avatar
armracing
hi ya i have recently put a rst engine in my orion does same as what urs is doing well annoying. basically loosing fuel pressure when standing a while.
Old Jan 7, 2005 | 02:46 AM
Big AL's Avatar
Big AL
Bttt
Old Jan 7, 2005 | 06:49 AM
220TC's Avatar
220TC
I believe there is something that keeps the pressure in the system, I think its called the fuel accumilator and its before the filter but Im not too sure, can anyone confirm ?
Old Jan 8, 2005 | 01:55 AM
Big AL's Avatar
Big AL
I'll have a looksee in the afternoon. Cheers.
Old Jan 8, 2005 | 04:32 AM
vroooom ptssssh
It Wasnt Me!
Accumulator, on my car theirs one at the back line comes off fuel pump to it, and i think one at the front beside metering unit. will ehar it hissing once u turn car off
Old Jan 8, 2005 | 10:04 PM
Big AL's Avatar
Big AL
Accumulator's not hissing, and all electrical plugs are giving readings so next on the agenda is to change fuel pump.
Old Jan 9, 2005 | 03:50 AM
vroooom ptssssh
It Wasnt Me!
test fuel pump with a live feed off the battery and prob try an earth too, if no work then theirs the prob, check fuel pump relay too under dash on driver side.
Old Jan 9, 2005 | 07:52 PM
Big AL's Avatar
Big AL
Fuel pump is priming as can hear it buzzing, just doesn't appear to be pushing fuel up though.
Fuel pump relay, will have a look for this. Cheers.
Old Jan 10, 2005 | 03:41 AM
vroooom ptssssh
It Wasnt Me!
fuel pump relay will be ok if pump is priming. check metering head multi plug is giving power?
Old Jan 10, 2005 | 08:00 PM
Big AL's Avatar
Big AL
Mate is going to change fuel pump sometime this week, fingers crossed
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
