rear bumper lower section
Old Nov 1, 2009 | 08:54 PM
airzfocus's Avatar
airzfocus
Default rear bumper lower section
just wondering if the lower section on a rear focus zetec bumper will split or is the bumper a whole unit? cheers
Old Nov 5, 2009 | 11:58 AM
Tony-is's Avatar
Tony-is
Default rear lower section
Hiya Mate yes it will split but you will need to remove the back bumper
if you have a ramp 20 minute to take it off
Old Nov 5, 2009 | 08:21 PM
airzfocus's Avatar
airzfocus
Thumbs up
nice one mate for your reply,
Old Nov 5, 2009 | 09:31 PM
RichieST's Avatar
RichieST
No it won't come to bits! And 20 mins to undo about 6 screws and a couple of clips?
Old Nov 6, 2009 | 08:35 AM
Tony-is's Avatar
Tony-is
Default lower bumper 2006 pre facelift
sorry mate what Year, just yesterday did Focus 2.0 zetec 2006 two screws at top near opening at either end,underneath 2 plastic screws remove a couple of the arch liner screws holding end of bumper inside under inner arch cover is a 10mm bolt one on either side remove the power cables to fog and reversing light pull gently on either end near rear wheal a locating lug which clips in it will come out with a little pressure ease back the bumper, you will now see how the bottom trim is clipped in you will need a small screw driver and a little bit of patience yopu will also need to drill out 2 rivets no biggy Hope this helps
Old Nov 6, 2009 | 04:59 PM
airzfocus's Avatar
airzfocus
sorry should of sed what year 1999 on wards to bowt 2004 cheers
Old Nov 6, 2009 | 06:13 PM
RichieST's Avatar
RichieST
100% certain bumper does not split into two on a mk1 focus mate!!
Old Nov 7, 2009 | 09:07 AM
Tony-is's Avatar
Tony-is
Default Missunderstanding
Iam also 100% it won't split sorry confusion on the year my appologies,
for what it's worth my son's which we colour coded (red) with St rear spoiler looks sweet
3drRich
Sep 13, 2015 07:32 PM
Bailes1992
Sep 3, 2015 02:17 PM
Ade
Aug 31, 2015 06:41 PM
borboyous
Aug 22, 2015 11:17 AM
