Help with gotech
Hi people
My mate is running go tech mfi ecu system on his s2 however we are having trouble setting it up. All the loom is installed etc, its just we cannot get the car to run. We have downloaded all the software and had 2 maps sent to us by jamsport and have loaded them, and still the car won't run. We have tried tweaking different factors on the map but just cannot get any real joy.
The best we've had is the car running on like 2/3 cylinders, and it wud actually idle at one point. However when you put the throttle down, the car ran worse and stalled. It seems to be the running and timing of the spark, but what we cant understand is why should it be wrong if we have had maps sent by jamsport....?
Has anyone else had any problems with this. I thought these things were meant to be easy to use.... It is an gotech mfi ecu, not the pro version.
Thanks
Thanks
yes mate every thing is fine i did ring u guys about the dizzy wiring and have done that as instructed i did try to ring u at work today but u was out. I was told to ring back on thursday it is a realy weird falt and living on the isle of wight i cant get to a tuner easily
unless sum 1 wants a holiday lol
have you tried adjusting the potometer to any effect and you sure you've put leads back on right way. you really need to get a afr in the tailpipe to see what is happening with fuel as all any of us can do is guess at moment
i think im going to get a lambda fited to help the ecu, if i could get it to where i worked and if i new my boss would not moan i would use our mot station's gas analyzer
Just a thort but i did fit a veinerpully to my engine just after i removed it from my old rs (on mfi) and instaled it in to my new 1 (with the goetech in) could i have it dialed in wrong by a few diegrees,also i have managed to get the car to run realy ruff tonight on full throttle but it seems to rev its sealf up and down whilst the throttle is head fully open then cuts out if i take the power off,thear is a strong smell of fule to and the plugs eather soot up realy badly or are soaked in fule and it seems to run on 3 sum times 4 cylinders,
all sensors are working fine as i checked them and wiaring seems to be ok ?
Joe1199
Apr 25, 2008 08:15 PM
